Question about Dishwashers
My dishwasher will fill with water, but when the wash cyle starts it does not sound like the blades are turning it makes noise, but does not wash
    Sergeant:
    Champion:
  • 323 Answers
Remove the occilating blades and rinse with water
water needs to go through the blades for them to spin, so if no water is flowing through them you need to clear them.
Posted on Sep 12, 2009
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
The machine starts but then makes a continuous churning sound as if it is stuck in the program.
If it is not washing the dishes, make sure the door is closed correctly. If it still makes that noise, check to see if water is filling machine, or that water is turned on. Could be the fill valve if these suggestions don't solve your problem
Dec 23, 2009 | Candy Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Ge nautilus/dw
it sounds like your dw wont drain. check air gap cap on sink, if there. then drain blocks.
Dec 24, 2008 | GE Nautilus 24" Built-in Dishwasher
Amana Dishwasher
sounds like something is jamming your wash inpeller start at the washer arm and go down till you get to the wash impeller and see whats sticking it like broken glass small peice of bone toothpick etc
Jan 19, 2008 | Dishwashers
Bosh dish waher
Does it make the same noise when it's just filling or just when the motor starts? Usually just filling the dishwasher opens a valve and doesn't run the pump. If it makes noise during filling the valve may be getting hot and shorting, or may have a loose connection, or air may be in the water supply line causing the valve to bounce. If it takes a long time to fill the filter may be clogged.
Nov 30, 2007 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Dishwashers Logo
146 people viewed this question
Top Dishwashers Experts
Owen Barnes
