Question about HP DesignJet Z2100 InkJet Photo Printer
Trying to print a Power point slide on z2100 --- getting format error 60:01
Hp design jet z2100 printing in mirror image
I would recommend uninstalling the print driver, going to HP.com and downloading the latest driver and reinstalling it.
Feb 25, 2014 | HP DesignJet Z2100 InkJet Photo Printer
Error 48:00
Unsolved - http://h30499.www3.hp.com/t5/Printers-Designjet-Large-Format/designjet-z2100-48-00-error/td-p/991800
Nov 12, 2013 | HP Designjet z2100 44 Inkjet Photo - Same...
It's a firmware error.
Unplug the power cord. Wait a few minutes and plug it back in. Power up. If the error is gone...good.
If the error comes back, go to hp.com and download new firmware.
Sep 14, 2012 | HP DesignJet Z2100 InkJet Photo Printer
ERROR 08:11 HP DesignJet Z2100 InkJet Photo Printer
08:11 error = no communication between formatter and front panel
Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
If the error persists, you are going to need a tech to do the following:-
Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel.Check that the connections between the Formatter and the Main PCA are not damaged and are correctly connected.
If the System Error continues, replace the Formatter
If the System Error continues, replace the Main PCA
If the System Error continues, replace the Front Panel
Nov 07, 2011 | HP DesignJet Z2100 InkJet Photo Printer
We use hp T770 HDD, error massage 79.03 when loading, after show preparing print system massage in a few minutes. ask for restart but after restarted the problem persist. please kindly help us if there any...
79 errors are often linked to firmware. Unplug the printer from power as well as any network or USB cables you may have plugged in. If the printer will restart without an interface cable connected then it is likely a bad print job. Clear all jobs from the print queues and then plug in the interface cable. If printer continues to stay at ready, download the current firmware and install it. This should resolve the problem.
May 25, 2011 | HP DesignJet Z2100 InkJet Photo Printer
I have a Designjet z2100. I loaded the drivers from the support site. Whenever I print, the printer display reports wrong file format. I am using window 7 64 bit and have tried using windows update to...
Next time include the System error code, in this case 61:XX.
Power off and remove the power cord. Reconnect and power on. Make sure that the correct driver is loaded.
Make sure that the Graphic language setting is correct.
Resend the file to the printer.
Make sure that the Firmware is up to date. Upgrading the Firmware will re-install the PostScript fonts.
It is also possible that the file is password protected.
Do all files fail?
Mar 25, 2011 | HP DesignJet Z2100 InkJet Photo Printer
HP Designjet T770 HDD error 61:01 wrong file format. The printer cannot process the job. There are only 2 types of graphics language setting in printers Menu HP-GL/2 CALS/G4 What do we do, we are...
Did it ever work?
You are using the Post Script drivers, right?
Power down the printer from the back. Disconnect the power cord. Plug it back in and power it up.
Check the graphic language setting of the printer(look at the User Guide)
Resend the file.
Upgrade the firmware to the latest version (www.hp.com/#support)
Feb 09, 2011 | HP DesignJet Z2100 InkJet Photo Printer
Warning. Color sensor may not be working properly. If problem persists call HP.
The listed error message is accompanied by the error code "58:10"
This error code can mean one of two things. Either the color sensor (the spectrophotometer) is malfunctioning - in which the error code would persist and a technician would need to be called. Or the sensor picked up a piece of lint or dust when doing its self-calibration - in which case it would come up as a single occurrence.
Here is a follow-up suggestion if there was any further concern. With the following steps, the spectro instrument (along with the print head) can be inspected. To do that, select "Replace print head" from the front panel and then turn of the power (hard switch on the back of the machine). With the printer off, open the tinted glass and slide the carriage over. This should allow the carriage head with spectro instrument to be brought into view for inspection of an lint or dust, etc. To restart the printer, just close the tinted glass and power the printer back up from the hard switch.
Nov 02, 2009 | HP Designjet Z2100 InkJet Printer
Error message: 38 memory full
you may have some corruption on the power point .
try printing only one page at a time.
if it refuses to print a certain page you have found the issue.
Feb 29, 2008 | Lexmark C510n Laser Printer
HP DesignJet Z2100 InkJet Photo Printer Logo
261 people viewed this question
Seeker5211
Seeker5211
