Question about Sansui TVS203
Have a sansui tvs273 tv. Need to switch it from
Have a sansui tvs273 tv. Need to switch it from over the air stations to cable, but the set has no menu button. Original remote lost. Universal remotes work for channels and volume, but not the menu button. How can I get to the menu?
    Scholar:
  • 61 Answers
If your set does not have a menu button built into the set your out of luck unless you can find a replacement or universal remote.
Posted on Sep 13, 2009
I have a picture but no sound on my sansui tv,can i get the sound back ?
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Some ads with posts too might help you.
May 29, 2012 | Sansui 32" TV
I have a Sansui SLED 2280 that I'd like to use without cable input. How do I switch to regular over the air (no cable) antenna? Thanks
To switch from cable to air or vice versa on most Sansui flat screen tv's including the SLED2280, go into the menu. Select "channel" on the screen. Press "enter" on the remote. Select "auto ch mem" on the screen. Press "enter" on remote. Select "signal type" on screen. Press right arrow button or right volume button on remote to change signal type (cable or air). To program channels into tv, select "automatic search" on screen then press "enter" on remote. Wait for search to finish.
I hope this helps you.
Bobya
Dec 19, 2010 | Sansui Televison & Video
What is the remote control code for the Sansui TV Model TVS273?
HI,
I THINK CODE FOR UR SANSUI TV IS "0463".
OK
Dec 13, 2010 | Televison & Video
Lost remote of sansui tvs273, want to access menu
Press menu on the TV, hope this helps
Mar 24, 2010 | Televison & Video
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
My new TV is set for cable. I do not have cable, I have an anten
Sansui TV's come from the factory set for CABLE. If this is a HDLCDVD320, you will have to go into the menu to change the signal type to AIR, then run the automatic search to program in your channels. Their free customer service line is 800 289 0980.
I hope this helps.
Dec 28, 2008 | Televison & Video
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Cable tv on a 1315
You have the set in standard air mode rather than cable mode. I am not familiar with your particular model, but you should be able to switch it to cable (assuming that it is cable ready). Check for a switch on the back or front. If there is no switch, there should be a menu option for changing the set to receive either over-air or cable. Check under the setup menus.
Dan
Apr 07, 2008 | SansuiM1315 TV
Sansui TVS273
This tv is not digital.
Mar 22, 2008 | Televison & Video
Televison & Video Logo
255 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
