Question about HTC Touch Diamond Smartphone
HTC Touch Diamond screen alignment
My Touch Diamond is locked and the screen taps have gone out of alignment. I can only hit #3 by tapping the far left of the screen. When I tap "Unlock" on the bottom left it opens menu instead (on the bottom right). I've tried to hard reset it according to user manual but it won't!
    Problem Solver:
  • 6 Answers
Hi
with the one i have, i have to take the battery out leave it for ten minutes and try again- if that doesnt work do it again -
get someone to phone you - try and tap the settings.
If this doesnt work - try the above again -
after 3 /4 times you will be able to get into settings and realign......
cheers
Posted on Sep 13, 2009
I went cleaning my htc p5500 screen with a dap clothes and rub it up and down now the touchscreen isnt working,jus would like to know if i reboot it will the touchscreen work?
FOLLOW this steps and fix it. God bless you
  1. Hard Reset
    • 1
      Pull out the stylus from the back of the HTC Touch Diamond or the side of the HTC Touch Pro.
    • 2
      Using one hand, press and hold the volume down button on the left side of the device, the power button on the top of the device and the circular button on the face of the device. It is generally easiest to hold the volume down button with your thumb, have your palm over the LCD, press the power button with your index finger and the circular button with your pinky.
    • Sponsored Links
    • 3
      Continue to hold the buttons down while you turn the device over to access the back side. Use the stylus to press the "Reset" button, located near the end of the stylus cavity on the Diamond, and by the port on the bottom of the device on the Touch Pro. Release the "Reset" button, but do not stop holding the volume down, power and circular buttons.
    • 4
      Turn the HTC Diamond over and watch the LCD. When a message appears saying that this operation will delete your data, release the three buttons. Press the volume up button to complete the hard reset.
    Clear Storage
    • 5
      Slide your finger to the right along the bottom of the LCD until the "Settings" option appears. Tap "All Settings" on the device.
    • 6
      Tap the "System" tab on the screen and then tap "Clear Storage"
    • 7
      Select the drop-down box and choose "Clear Storage Only." Type "1234" into the text box confirming that you do want to delete your information and then press "Yes."
Jul 25, 2013 | HTC Touch Dual P5500 Smartphone
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
My touch screen doesnt respond properly. What could be the probable issue?
tap start>setting>system>screen>align screen, the calibration starts tap on center of +
May 20, 2010 | HTC Touch P3450 Smartphone
Htc touch diamond 2 screen is freezing cant call etc
1. Turn off HTC Home Sprint and Today Timeout. Settings -->Today --> Items --> Uncheck Today Timeout and HTC Home Sprint
2. Turn off Activesync. This can be done by closing activesync and going to Settings --> Phone --> Services --> Time synchronization and uncheck time sync. This will stop activesync from starting all the time
3. Turn Roaming to "SPRINT ONLY". Settings --> Phone --> Services --> Roaming --> SPRINT ONLY
Open the Task Manager (top right corner icon), clicked on the “tool” icon, then the “button” tab, and changed the “Enable the X button to end running programs,” selection form “End programs by tapping and holding X” to “End programs by tapping X.” Now, when you tap the “X” to close a program, it actually closes, and frees up more system memory. The same result can be achieved by tapping and holding the “X”, rather than changing the setting, if preferred. The objective is to CLOSE the programs and free up the memory.
Mar 23, 2010 | HTC Touch Diamond Smartphone
When i tap for example on the top right hand
Try calibrating the screen from settings. It should work then.
Jan 04, 2010 | HTC Touch Diamond Smartphone
My little girl was playing with my htc and put a 3" wrapping tape on the touch screen. when i was taking it off, the clear cover was coming. I pull it about half way before I took the tape off. then the...
Try calibrating the device again.To recalibrate:
Tap Start >> Settings. Go to System tab and tap on Screen. Now select to Align/Calibrate screen from there and follow the instructions. Tap Ok after the calibration is complete. Soft reset the mobile and then check again,
Nov 11, 2009 | HTC Touch P3450 Smartphone
Launch TouchFlo", but several taps
Couple questions to clarify:
Did you reboot the phone?
Is this the stock version (is this how the phone came in the box?)
Have you recently installed any programs?
Thx
Sep 06, 2009 | HTC Touch Diamond Smartphone
Screen alignment could not be done
I accidentally click on something and my screen alignment for my HTC mobile phone has run significantly... When I tried to align the screen from the setting, it only write that tap firmly and accurately on the target. the target will continue to move until the screen is aligned. Till now, i tried many times but the alignment is still out
Mar 25, 2009 | HTC Touch HD Smartphone
Hard reset for a HTC Touch Diamond
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
2. On the System tab, tap Clear Storage.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
HTC Touch Diamond Smartphone Logo
1,302 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
