Question about Denon AVR-1905 Receiver
Goes to standby with fast blinking red light after 5 seconds
When I power the receiver on it goes to standby with a fast blinking red light after round 5 seconds. I've tried unplugging everything, powering off, and removing the power plug before trying again, nothing works. It seems like the safety cutoff is doing something, but with nothing plugged in, why would it have a problem?
From my experience you need to replace the Hi power module
Posted on Sep 26, 2009
All of a sudden stopped working and won't turn back on. been 12hrs. when power is pressed, it turns on for 2 seconds and then standby lights blink again and it turns off
This could be caused by a direct short circuit on the speaker outputs. Try disconnecting all the speaker connections at the back of the receiver and then power back on. You can also try a factory reset by holding the surround mode + clear button for 3 seconds.
Feb 14, 2016 | Marantz SR7005 Receiver
My Sony tv won't power on its goes on then stays blinking on standby 14 blinks on red
Try unpluging the tv for several minutes and then plug it back in and turn it on and see if that helps
May 22, 2015 | Sony Televison & Video
My sr5004 marantz receiver has gone into standby with the indicator is blinking how do i get ride of it
If the red led is blinking fast (8x/second) the power supply is likely damaged and the unit will need to be serviced. If blinking slow, the most likely cause would be a shorted speaker connection. To help find the cause, unplug everything including the power and speakers. Connect only the power and try to turn the unit on. If the light doesn't blink, you know you have a shorted connection. Power off and connect the inputs and then power back on. If the light is not blinking, you know the problem is with an output connection. Just find the bad connection by process of elimination.
Manual: http://us.marantz.com/DocumentMaster/US/SR6004-5004_U_EN.pdf
Sep 27, 2014 | Marantz SR5004
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Mar 09, 2011 | Sony Televison & Video
I have a Sony KDS-R50XBR1 that has no picture. When I turn on the TV, the green Power/Standby LED light blinks for about 30 seconds, then turns red and blinks five times. The Power/Standby LED repeats...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Jan 19, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
When i power on the device, it comes on but goes off about 5 seconds later.
Hi...
1st thing to check is for GOOD speaker connections at both ends
and not mixing A and B speaker wiring.
A Denon is usually a good brand. Might be worth servicing if need be.
Sep 20, 2008 | Denon AVR-1905 Receiver
Denon AVR-1905 Receiver Logo
1,226 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
