Question about Samsung CLX 3160fn All-In-One Printer
"transfer belt error"
Had to get a piece of paper "unjammed." Now the machine makes all sorts of groaning sounds and the screen reads "transfer belt error." Paper will come through the roller, but nothing prints on the paper. Where is the transfer belt, and can I fix the problem without calling in a technician?
How to deal with error code E00012-001of canon irc5870
E012 occurs if the machine cannot read the patch when trying to calibrate color. The main causes are- 1) dirty patch sensors, located on the right side of the machine when you open the right door, just above the transfer belt-typically a off white colored plastic piece. you would have to slide to the rear and blow (3) holes out with canned air. 2) ripped belt- would have to be replaced. 3) fatigued developer causing patch to be read incorrectly. 4) faulty motor on Image transfer Unit.
Jun 07, 2014 | Office Equipment & Supplies
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
As soon as you press print it acts like it's going to work then the wheel makes a sound and it stops, like the wheel is locked up or something. It says printer error. Remove back access and unjam the...
That usually means that the paper feed rollers are not pushing the paper into the printer. Take a paper towel and some isopropyl alcohol and clean the rubber rollers were the paper is set and feed into the machine.
Aug 25, 2010 | Office Equipment & Supplies
My dcp 150c printer has been jammed for weeks, i have done everything it said in the manual but it won't unjam
This Brother printer could have a piece of paper stuck in it. When a paper jams, assemble the jammed page pieces to make sure all the pieces came out.
A jammed paper can also knock loose the paper detect arm that senses a paper in the machine. This detect arm is usually near the platen (The roller the print head prints against) to detect paper in the machine. If this arm is stuck, it could be sensing paper when there is none.
Rubber paper rollers should all be cleaned with rubbing alcohol or a mild soap solution (I use Windex) to prevent feed jamming.
Mar 28, 2010 | Office Equipment & Supplies
SERVICE CALL 14 XFER ROLLER Have installed new transfer belt. Still had error message. Came here and read tips. Cleaned the sensor both in the printer and on the transfer belt; reinstalled. Still...
the transfer roller is a foam roller that transfers the toner onto the paper. It will be visible with toner removed, a little wider than a piece of paper, and about the thickness of a roll of quarters. I don't know how to physically remove it on your model, but transfer roller issues in general can be remedied by removing the transfer roller and wrapping it in packing tape until the tape comes off clean.
While you're in there, vacuum everything out for good measure; but never, ever use canned air on a laser printer.
Jan 03, 2010 | Minolta magicolor 2200 DeskLaser Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
Supply Memory Error
It sounds like you are having two diffrent problems. I don't think they are associated with each other.
First, the memory supply error. The cartridges on this machine have a chip. The chip could very well be faulty causing this supply error message. Change the black cartridge and see if the message clears. if it dosen't then the antena that reads that chip needs to be replaced. I suspect the cartridge is the problem.
Second, the paper jams. This can be caused by a worn p/u roller as you mentioned. Sounds like the jam happens first then the error, based on your description.
The black thing you refer to on the door is called the "transfer belt assembly".
Aug 21, 2008 | HP Color LaserJet 2600n Printer
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
Canon clc 5100 E075 error code
E075 error is a HARD error. Im means, it will not reset by turning the machine OFF and ON. The reason for the error is the Black transfer belt is moved too much in one dirrection, causing a fault. the belt will have to be moved to center by hand, then the E075 cde can be cleared in service mode. (function > f-misc-p> screen 2> E075-rls. then shut off.
its best to get a canon tech involved, because there is most likely other problems.
May 13, 2008 | Office Equipment & Supplies
Samsung CLX 3160fn All-In-One Printer Logo
273 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
