Question about Welding Tools
I am using flux core wire. The wire comes out. I
I am using flux core wire. The wire comes out perfect until I contact the work piece. I cold stand there and feed the whole spool of wire through it no problem. as soon as I contact the work piece the wire immediatle sticks inside the whip. I tried a bigger brass tip with the whole in it but still the same problem. I am also using the anti splatter paste. The wire seems to stick inside the coil in the whip.
Make sure your wire speed is not to slow when you strike an arc. When it is, it will usually burn off right at the contact tip
Posted on Nov 25, 2009
  • 631 Answers
Is your grab rollers tight? Is it a new liner in the lead? If you are using .035 wire you can use a .045 tip. I generally use one size larger then what is required. You have a lot less problems that way. When you use flux core wire on most wirefeeds you have to reverse your positive and negative leads inside of the welder I assume you did that? If there is any moisture inside of the liner it can stick because it is grounding out when you start to weld.
Posted on Sep 11, 2009
Wire wont feed on my welder
I would call miller and get a number for the closest repair station. They have a three year parts and labor warranty. 1-920-735-4505
Jan 10, 2015 | Miller Multimatic 200 MIG TIG & Stick...
Can I use 0.030 Flux Core Wire in my Lincoln Electric SP170-T?
Use the .030 flux core wire with the amperage settings for .023 solid. If you cannot find .023 settings then just set low power first and play with it to see what works.
Aug 26, 2014 | Welding Tools
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Apr 03, 2014 | Campbell Hausfeld ® 115V MIG Flux Core...
Will a ya219b snap on by century mig welder weld flux core wire
Are you using knurled rollers? Check the wire. Is it reversed polarity. Flux cored wire is very voltage sensitive.
Jun 14, 2012 | Century Welding Tools
Lincoln Powermig 350MP welds for a short time and then stops with a fault code 81 ,which does not appear in the owners manual
Hi:
Code 81 mean an overload to the system, this problem occurs when the wire is not running freely from drive rolls to the contact tip. To avoid this problem do the following troubleshoot.
1) Make sure you have the right size and type of drive rolls for the wire you are using. P.e. if you are using steel core wire (gas use) you need U-grooved type, if flux core wire then you need knurled type.
2) Check your tension at the idle roll pressure setting, this one must be 3-4 if using metal or flux cored wires. Less for aluminum and more for S.S.
3) Check your liner if there is any kink on it, change it.
4) Change your contact tip if needed.
5) Check the tension on your wire spool holder, this one also must run not so freely but free enough to avoid wire nesting.
Hope this help.
If this was useful to you please vote. Thanks.
Your wire must run smoothly
Mar 23, 2011 | Lincoln Electric Welding Tools
SMALL PUDDLES NO PENATRATION WELDER IS FARM HAND 115 VOLT MIG//FLUX CORE WIRE FEED PUT ON ANY SETTING NO DIF CANT FIND MODLE IT HAS CHPOWER.COM WEB ADDRESS
Hi:
If you are using flux core wire you need to switch the polarity of the machine. With flux core wire, your ground clamp becomes positive (lead) and your gun the ground. All you need to do is switch the cables above the feed rolls.
That will take care of the problem
If this was useful to you, please vote. Thanks.
Mar 20, 2011 | Campbell Hausfeld Welding Tools
Just purchased and tried to use my flux welder. It jams before flux even comes out the handle.
have you tried adjusting the tension on the flux wire? before you start feeding the wire into it make sure there isnt any kinks in the wire. seems like it doesnt take much for it to bind up once you get start welding with it im sure you will run into this problem quite allot. usually its from welding the wire to the tip. i have to be honest it can ve a pain in the ***
Dec 30, 2010 | Firepower Flux Core Wire Feed Welder 88...
Wire won't feed, motor runs and it grips the wire. I can pull it through by hand but it is hard to do .Is something in the line restricting the wire?
I wll check the gun liner and see if it is kinked. Check also your contact tip, must be same diameter as the wire, if you are running flux core wire, oversize your tip, example if wire is 030, then use a 035 tip. Check also drive rolls, for flux core must require knurled drive rolls instead of grooved ones.
Dec 18, 2010 | Campbell Hausfeld 115 volt MIGFlux Core...
Lincon mig 100 need wire feed wheeh for solid & flux core
solid wire drive rolls are not the same as flux core. Solid are U-grooved while flux cores are knurled. Any welding store can get it for you. Perhaps you can find one that has twin groove.
Nov 05, 2010 | Welding Tools
I have a problem with a jerking motion while Im trying to weld. the wire feeds out good without the tip on. I replace the tip but I havent replaced the cup but Im using flux core wire also. What could be...
I have found that keeping the gun lead as straight as possible fixes this problem. Also it is sometimes recommended to use one tip size bigger when welding with flux core wire. My last spool was radnor flux core wire .030, and a .035 tip keeping the lead as straight as possible and it welded extremely well. If that doesn't solve it you should take everything apart and clean it / blow it out with compressed air.
Oct 27, 2010 | Hobart Handler 140 Mig Welder
Welding Tools Logo
154 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
