Question about Karcher G3025OH Pressure Washer
Pull trigger, no water from wand
This is the second pressure washer we've bought from costco doing the same thing. you can tap on top of wand and sometimes it works
  • 174 Answers
The wand is plugged.
Posted on Sep 17, 2009
Husky 1800 Pressure Washer motor will not turn off when wand trigger is released
I think you have one of two things going on hear, an overpressure problem or a carburetor issue with the engine.
Jul 25, 2017 | Husky Garden
Why do I have no pressure in my Gerni water blaster.
check for a blocked jet at the end of the wand
check for hose collapsed internally and blocking of pressure water
check for faulty pressure control regulator
Jan 03, 2016 | Garden
Hi I have a homelight UT80546 pressure washer that stalls as soon as I turn the water on. I have replaced the pump with a brand new one that does the same thing. It also has a new carburetor, fyi
My neighbor has one that will do the same thing if the inlet water pressure it too high. I don't know if there is supposed to be a bypass for this water until the trigger is pulled or not. But once the trigger is pulled on the wand the problem goes away. So if you just pull the trigger when turning the water on that should solve your problem.
Oct 02, 2014 | Garden
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
HOW DO I DRAIN THE WATER FROM MY HP WASHER FOR WINTER
What I've always done is just disconnect the water hose then start the washer and pull the trigger till no more water comes out. You don't want to run it very long at all after there's no more water though, you can quickly overheat the pump if it is ran without a water supply for too long. I've been doing this for the past 3 years with one of my washers and haven't had any problems with the pump.
Oct 05, 2012 | Powerboss 020309 3000 psi 2.5...
Black and decker electric power washer nothing coming out of wand all water coming out trigger.
Either the pressure tip or wand are blocked or the valve in the trigger is broken. Remove the high pressure tip and either try another tip or pull the trigger without a tip on the wand to see if you have the same problem. If available, try another pressure gun on the hose.
Jul 25, 2012 | Garden
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
Shuts off when high pressure wand is attached
Hi Brian. Welcome to FixYa I am Kelly. This sounds as if the bypass / unloader valve is stuck in place and the pump id dead heading causing the unit to shut off. (There is most likely some corrosion in the unloader / bypassy valve assy / housing. What you can try is pouring at least 3 oz of oil into the water inlet assy and briefly.... like VERY briefly switch the unit on then back off. Then let it sit over night. The next day connect everything for normal use then turn the unit on again briefly. Use a bucket to PURGE the oil that you put through the system by squeezing the wand Power SW Off until the oil purges. Then switch the unit on and rapidly trip the trigger at 0.5 sec intervals or less. If it trips off wait 5 mins and try it again. Do the rapidly tripping the trigger on the wand routine for about 20 seconds. Your forcing the bypass unloader valve to cycle trying to clear out any debris / corrosion.
This works often and well. There are exceptions. Hopefully it will work for you.
Thanks for using FixYa.
Kelly
May 07, 2010 | McCulloch FHH18A Electric Pressure Washer
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
Karcher G3025OH Pressure Washer Logo
192 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
