Question about Microwave Ovens
With my micro pluged in the control panal displayes set clock but will not respond to any fuction
  • 269 Answers
Hi! your panel is defective.
Posted on Sep 12, 2009
How to set the clock on ge space maker micro wave
http://products.geappliances.com/appliance/gea-support-search-content?contentId=17872
Quoted from link above:
To set the clock on most GE microwaves:
  1. With the microwave door closed, press CLOCK.
  2. Touch number pads that reflect the time of day (1:45 would be 1, 4, 5).
  3. On some newer models, indicate AM or PM for morning or evening.
  4. Press CLOCK or START to lock in the time.
If you prefer not to display the time:
Disconnect the power for 30 seconds. After restoring power, do not set the clock. If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Mar 21, 2018 | GE Microwave Ovens
Why isn't the display responding?
The interdace that converts pushes into signals may have died, you may need a new front panel...they may be available...had to change 2 on our old toshiba
Jul 15, 2015 | GE Microwave Ovens
Sharp carousel microwave
You may need your main control panel repaired
Oct 21, 2013 | Microwave Ovens
GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Jun 24, 2009 | GE Microwave Ovens
Microwave won't start
Did someone recently clean the front panal with a wet cloth or spray it with cleaner? Was it near a very steamy source? If the touch panal gets moisture between the layers it will no longer work. Some times it will dry out eventually and start to work again. Many times replacing the panal is the only fix.
Eric
Jun 08, 2009 | Whirlpool Microwave Ovens
Clock and temperature display not working on my jenn-air oven.
The problem is a failure of your latch mechanism. It's a bad design and should have been warrentied by a company that cared about people more than profits.
Here's the real fix! 1. Go to radio shack and buy the 100uF (microfarad) 35 Volt capacitor that costs $1.49 cents as of fall of 2010. 2. Open your oven panal with the 4-7 screws depending on model. Remember to turn off the circut breaker to your oven for safety's sake. 3. Remove the ribbons holding the panals on, remove the clock display panel. 4. De-solder the C3 capacitor (68uF 35V) capacitor. Note the polarity marks on the capacitor before you remove it. Now solder in the new 100uF 35V capacitor with the correct polarity. 5. Reassemble the oven display by connecting ribbons and putting panal back in screws and all. 6. Have a beer, glass of wine, or at least a pat on the back for saving over 300 bucks in repair bills.
(If you can't solder, meet a neighbor or friend who can and give them a beer or dozen cookies for their help.)
This fix took me one dollar and 50 cents worth of cash and all of 10 minutes of my time from the moment I started unscrewing the display to the moment I put the breaker back on and saw my fix worked.
Cheers! Screw the repair man and his rediculous fixes!
Nov 12, 2008 | Jenn-Air JMC7000 Microwave Oven
Microwave panasonic model nn 6358 about 10 years old
In most cases, you press Clock, enter the numbers for the time, then press Clock again, or possibly press Start.
Sometimes you have to press Clock, Clear numbers, then Clock or Start.
Or Clear, Clock, numbers, then Clock or Start.
In some older models, they had a very small mechanical clock button located at the top right corner of the controller near the display window. If yours has that, press it, then the numbers, then that button again or Start.
If this doesn't do it for you, could you post a clear photo of your control panel?
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 21, 2008 | Microwave Ovens
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
