Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Water won't stop right away in door when glass pulled away
  • 4,070 Answers
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Posted on Sep 11, 2009
Diagnose GE Ice maker works makes ice! continues to eject ice when glass is pulled away in door
The switch is probably sticking. It may be the lever is sticking.
Oct 12, 2014 | Refrigerators
Just bought a side-by-side wirlpool refrigerator and it leaks water for a few seconds after you pull the cup away. Eventaully it does stop leaking, but why doesn't it stop right away. I just bought it...
Hello, Thank You for using FixYa. I will be helping you today.Try running about a gallon or two of water out of it to get the air out. It can also be not enough water pressure to the unit from your house that causes the same issue.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I just changed out my filter on my side by side Kenmore yesterday. The ice maker still works...however, when I went to dispense water from the door when I pulled the glass away from the lever the water...
Your switch is sticking and could be you got debris in the shut off part of the hose when you changed the filter . But I'm guessing switch,exercise it a few times and see what happens.
Mar 28, 2011 | Kenmore Refrigerators
Brand new GE Profile GFSF6KKYCBB French Door with external ice and water dispenser. After filling a glass of water, pull the glass out and water turns completely off as expected. Two seconds later, the...
Sorry to read about your problem, I hope this helps you out.
factory defective, call in warranty service
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | GE GFSS6KKYSS (259 cu ft) Bottom Freezer...
How do I get the inside glass panel back onto the door?
You will find sets of screws ether on the outside edge of the door OR on the inside panel. You can NOT! use any glue to "seal" the Glass this will make everything smell like the sealant you picked to use. your door was probably used as a resting spot for something heavy and caused the doors skin to be bent OR when you Cleaned the oven with the clean feature it caused the door to warp. Your option is to get a replacement part to fix the problem you can stop by any appliance parts shop and ask them what the best thing to do is and/or buy the part there you can "pull the door" off the hinges by lifting the door straight up at you and take the part to the stop for help and or replacement
Feb 10, 2010 | Zanussi ZBF360 Electric Single Oven
Ge sxs model GSH25KGRB BB. We have water and ice in the door and when using the water in the door, the water doesnt stop running out even after you pull glass away and we have started to see water frozen...
your water valve might be bad it locate behinde the fridg on the bottom you need to pool out the pip from it to see if it still leak..
contact me at www.911servicetoday.com
Dec 30, 2009 | GE GSH25KGR Side by Side Refrigerator
Inner door seal
You need to disassemble the door and reassemble with the inner glass well in place, no need for a new door.
If the glass is damaged, call manufacturer and replace glass.
If some other part on the frame has bent, replace the faulty part.
The whole door is expensive.
To replace or refit the door glass you can do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagrams below as an example, I do not have Tecnik diagrams:
, click on picture to enlarge:
Contact Tecnik at the number listed on the owner manual to get diagrams for your model.
Apr 09, 2008 | Tecnik TKC1426 Electric Kitchen Range
Bosch SHU3302 diswasher - lack of water pressure
if you have water in the machine but it isn't pushing it or agitating the water you have a bad motor,if you think the valve is bad open the door and add water into the machine by hand with a bowl or glass,if it starts to agitate better then the valve isn't letting enough water in,the best way to check if it's spraying is pull out the top rack put a glass right side up in each corner of upper rack,if the glasses have a good amount of water in them after running for like 30 seconds then it sounds like it's working correctly,i don't know what you mean by water pressure,when it stops filling after like 2 minutes open the door,if the water level looks low or lower than normal then i would say you have a bad water valve,if water looks normal but not spraying or agitating the water you could have a bad motor or something is clogged stopping the water from spraying,but like i said when it starts to run and it sounds like the water isn't agitating as hard as normal add a few glasses of water and start it,if it sounds stronger then i would say the valve is bad not letting enough water in.
Jan 20, 2018 | Bosch Dishwashers
Spill into oven vents
The best way to clean the inner glass is to remove the door from the oven. With the door in the broil open position (first stop) pull up for about 2 inches until the hinge brackets are released from their stops. Close the door all you can and lift the door off the hinges. Lay the door on a padded surface and remove the 4 screws on the bottom. The outside glass will now slide out of its rail and you can clean the inside. To install just reverse the process. If you take your time and observe, it's not that bad of a job...Catriver..post back.
Nov 26, 2006 | KitchenAid KESC307 Electric Kitchen Range
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
102 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
