Question about HP Photosmart C6180 All-In-One InkJet Printer
HP C6180 printer install hangs on my XP Thinkpad T43
I have an HP C6180 printer directly connected to my wireless router. When I try to install the printer on a Thinkpad T43 running XP the installation process hangs during the "Checking system" phase.
  • carryonwilli Sep 11, 2009
    The install process hangs with the setup CD and with any of the three installers available from the HP web site.
  • HP Master
  • 6,487 Answers
If the installation hangs using the setup cd , the best thing that you can do here is to download the printer software from HP site and install it after that and that should correct the problem..
Posted on Sep 11, 2009
Can't connect Thinkpad t43 XP to C1000a wireless
Try connecting with the IP address of the router on the PC
Nov 02, 2012 | Apple Computers & Internet
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
I've been able to print from my laptop wireless to printer HP C6180. Only lately, printer was unable to get wireless signal. My other desktop could print wireless to HP C6180. I tried uninstall driver...
In this situation your wireless printer might require a power reset before you print each document. Though the printing activity will take place efficiently you will have to physically go and power the printer to enable it to print. This problem might require you to reload the firmware of the router and set the wireless printer to manual IP address in order to make it work seamlessly no matter how many documents you have to print.
Nov 30, 2010 | HP Photosmart C6180 All-In-One InkJet...
Adding wireless printer to thinkpad T43
If you have a wireless router, the printer will talk to the router and not to the thinkpad. You would have to establish a connection between the printer and the router. Then share the printer to print.
If you dont have a wireles router and you are trying to connect your thinkpad to the printer directly, the wireless card in the thinkpad should be in the adhoc mode. ( See Wireless card properties )
Hope this helps
Thanks
Ranjit www.supportminds.com
PS: Dont forget to rate me if you got your answer.
Aug 13, 2009 | IBM ThinkPad T43 Notebook
I re-installed XP T43 laptop and my wireless does not work
First thing is to check if the wireless device is working. Go to Control Panel - System - Hardware - Device Manager. Click on Network Adapters. Do you see the the Wireless card?
If not in Control Panel click on Network Connections, do you see a Wireless Connection? If not you need to install the correct wireless network driver, Check the IBM site again, there should be another wireless driver (there are a couple of different wireless card installed on T40 series ThinkPads).
THEN
If you succeed in installing the wireless driver and it is enabled.
Then click Control Panel - click on Network Connections - right click on the Wireless Networl Connection - Click on Properties and check if TCP/IP has been installed, if not install it. Check TCP/IP properties - make sure it is set to Obtain an address automatically and Obtain DNS Server address automatically.
Check the wireless settings on your other laptops, use this information to configure the wireless on the T43, ie the SSID, WEP or WAP settings
You should be able to connect to your wireless router and Internet now - let me know how it goes,
Mar 13, 2009 | Lenovo ThinkPad T43 Notebook PC
C6180 scan unable!! conection error reported
Get the right Driver's and will work fine than recalibrate the printer. .http://welcome.hp.com/country/us/en/support.html
Jan 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp Photosmart C6180
In order to have a network connection you need to connect your printer to a wireless router that you have. make sure that your computer is already connected to that network.
1. Connect the printer to the router wirelessly. Press the "setup" and then press the arrow key and look for "network". Press ok when you see "network". Press the arrow key and look for wireless setup wizard. After you have successfully connect your printer to the router press ok
2. Check the ip address of the printer by printing wireless configuration page.
3.install the software for the printer
Aug 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
Not able to see HP C6180 on SonicWall TZ 180
Not sure if you've done this already or not, but I would suggest installing the printer manually as a local printer, and create a TCP/IP port that points at the IP of the Printer. Rudimentary way to go, but should help.
-Backu
Jan 16, 2008 | SonicWALL Total Secure 25 VPN Gateway, WL...
HP Photosmart C6180 All-In-One InkJet Printer Logo
264 people viewed this question
Seeker5211
Seeker5211
