Question about GE JVM1750SMSS Microwave Oven
GE Microwave oven vent fan not working
GE Microwave oven
Model #JVM1750SM1SS
The exhaust fan will not work. I can hear the relay click in on high and low. Is there a way to access the vent fan motor without tearing out the microwave? It will still cook food, light works, turntable works...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 92 Answers
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Posted on Sep 11, 2009
Samsung microwave oven model SMH1622S exhaust fan will not shut off high fan and low fan will switch but the off dose not work.
On model SMH1622S, I would first check the hood TCO. It should be normally open (infinite resistance on a continuity test). If it has shorted, then the hood vent exhaust fan will stay on.
If that's good, then it is probably a shorted vent relay on the control board, which I can repair.
Details are here, where I also have a video showing how to remove the grille and controller assembly in about 5 minutes.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
The Fast Track repair manual for model SMH1622 is here. It will be useful.
If you have other questions, it's best to follow up with me directly.
(FixYa does not notify us directly when follow-ups are posted, so we have to log in to the site to see them.)
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 23, 2017 | Samsung Microwave Ovens
Ge microwave fan vent won't stop
Either a mechanical or electrical issue at the vent.
Dec 23, 2012 | Microwave Ovens
I have an GE Eterna Microwave Model Number: EMO3000HWW01 The microwave resets itself after aboout 10 seconds of use. Before it would do this and we would reset the time and date and it would work for...
It may be that the internal cooling fan is not working or the filters or air duct may be clogged, but it may also be a "noisy" magnetron.
First, check the filters. Then determine if the internal cooling fan is coming on.
I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
If that is working, and you have good air flow, then see this FixYa solution.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Sep 07, 2010 | GE JVM1650 1000 Watts Microwave Oven
GE MICROWAVE OVEN, MODEL JVM1750SM1SS, WILL NOT HEAT. EVERYTHING ELSE WORKS.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 19, 2010 | GE Microwave Ovens
VENT NOT SUCKING
I would suggest checking the filters, checking the duct work (including the outdoor vent) and if that doesn't turn up the problem, the hood vent exhaust fan blade assembly may have come loose on the shaft.
You can download GE owner's manuals and installation instructions here to help you verify the filter status and duct work.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Vent fan not working on high or low.
no, it is not controlled by a thermostat
Dec 13, 2008 | GE JVM1740DM Microwave Oven
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
Mircowave works, exhaust door opens, fan stop working
From looking at the owner's manual, it looks like the vent fan is only supposed to come on when the internal temperature of the microwave gets too high OR when you press the VENT FAN pad. Here are a couple of fan-related excerpts from the owner's manual, which can be found here: http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=JVM1840BD (or the better URL here: http://tinyurl.com/yn7r6g) Automatic Fan An automatic fan feature protects the microwave from too much heat rising from the cooktop below it. It automatically turns on if it senses too much heat. If you have turned the fan on, you may find that you cannot turn it off. The fan will automatically turn off when the internal parts are cool. It may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. - Vent Fan The vent fan removes steam and other vapors from surface cooking. Press VENT FAN once for high fan speed, twice for medium fan speed, a third time for low faw speed, or a fourth time to turn the fan off. Press the VENT FAN BOOST pad for extra fan speed. - Hope this helps.
Oct 31, 2006 | GE JVM1840 Microwave Oven
GE JVM1750SMSS Microwave Oven Logo
1,074 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
