Question about Samsung LTN1765 17 in. LCD HDTV
Screen is black and power indicator light blinks steadily
I just bought this 50" plasma and it has been acting up - if this is not a quick fix i may be forced to take it back to Sams club. any ideas??? I can't even locate a reset for it ( Samsung 50" plasma model # PN50A530SFXZA)...
Help
dsacco86
  • 1077 Answers
SOURCE: 50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Posted on Jun 17, 2009
SOURCE: 50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Posted on Jul 01, 2009
  • 610 Answers
SOURCE: screen is black & power indicator light blinks
power supply board has failed.
Posted on Oct 28, 2009
vinnyq
  • 157 Answers
SOURCE: Can I use any universal wall mount for my LG
Just check the weight and size restriction on the wall mount. As long as the weight and size specs of the TV fall within those allotted by the wall mount, you should be fine.
Posted on Nov 13, 2009
  • 8457 Answers
SOURCE: I have a Samsung LCD
Tries unplug,replug the tv it back like an hour later.The tv now should,resetting itself back to the factory setting.The tv now should work.Not,than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Oct 28, 2010
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
What can I do to fix my Sanyo tv off and on issues? It keeps blinking or flicking off and on screen but it works good and stable when playing video games I would appreciate any tips or help thanks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 01, 2015 | Sanyo DP50749 50 in. Plasma TV
My 50" Panisonic TV lost the picture and it black, when i turn it on the red power light comes on then starts blinking.
How many blinks you get, Panasonic has a diagnostic blink code to help with troubleshooting, it might indicate an issue with the internal supply, SC cards or main A module.
Jun 26, 2014 | Panasonic Tc-p50c2 50-inch 720p Plasma...
bad caps on the PS board and inverter if set is an LCD
Mar 13, 2011 | Samsung Televison & Video
My hitachi plasma TV P50A202 screen is black and the blue indicator is blinking
unplug unit for 1 minute turn off main power button plug in then press main power button and try!
Jan 10, 2009 | Hitachi P50A202 50 in. Plasma TV
50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Dec 19, 2008 | Philips BDS 4611 46 in. Plasma Television
Blue power light blinking 3 times
I am having the same problem, what was the solution to this problem? And how much did it cost to fix it?
Jun 21, 2008 | Hitachi P50T501 50 in. Plasma HDTV
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Samsung LTN1765 17 in. LCD HDTV Logo
1,030 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
