C500 toner recovery auger is bound up giving a code related to it.Is this a relatively easy fix or is it more involving.Any input is appreciated i'm going to the call blind.Thnx!
  • richie414 Sep 14, 2009
    Model: AB Dick CXP 3000
    Code: 21-01
  • sam gerban
    sam gerban May 11, 2010
    ned brand name,and code?
    Guru:
  • 389 Answers
You should apply to service service. This fault requires change.
Posted on Sep 13, 2009
E821 error code in canon IR 6570 ?
error code relative to the clogging of toner inside the waste toner auger tube. this will require a technician.
Feb 17, 2015 | Canon Office Equipment & Supplies
Auger does not turn
If the high speed impeller is turning, but the auger is not, there are 2 failure modes:
1. The sheer pin attaching the auger to the shaft has sheared. There is one shear pin on each side. This is an easy fix. Buy a new shear pin. Do NOT use a regular bolt.
2. The gear box between the 2 augers is broken.. This is an expensive fix and requires modderate skill for a DIY fix.
If the high speed impeller is not turning, it is likely the belt is broken between the engine and the blower. This is a relatively easy fix.
Feb 05, 2014 | Ariens Garden
I have one canon ir 2020 i copier machine how to all copies recovery at a time please infor me
To recover prints at time of failure is not possible, the device will need powering down to resolve issues such as error codes. E007 will need film replacement or clear code. E019 is waste toner need emptying, E010 is main drive motor maybe related to drum seizing from waste toner being full etc. image quality may be either film or drum. The drum Would look more streaky looking ==== could be bold and dark but will have straight lines within. and the film would be more blotchy/patchy/speckle y :;'";:;':':;;;':;';,. Please give more information if answers still not helping and whats been resolved so far
Aug 01, 2013 | Canon Office Equipment & Supplies
I have an ir6570 giving me an error code e0013, e0004 please help
This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
I have canon ir 6570 continueing errod code e0013 solution
This is the standard Canon code for waste toner feed screw is locked. Most likely someone reset the waste toner counter and the waste toner has backed up in the auger screw. You should first empy the waste toner bottle located on the right side lower right. Remove the two screws and empty the bottle you find. You may even have to remove all the associated covers motors and circuit boards to get to the waste toner system. You will have to either clear out the auger tube, or replace the whole assembly. Check for broken parts, bound up screw, fused toner, etc. I've done this a couple of times and it's not fun. I try to make sure that I empty the bottle at every 1 million copy mark just so this doesn't happen again. Good Luck.
Phaser 7400 error 929
Xerox Phaser 7400 error codes 929 - Please check your Waste Toner Auger Assembly if motor won't turn and when you done the sensor test and passed the Waste Toner Auger Assembly was jammed. I just fixed this problem here, just now!
Jan 13, 2012 | Xerox Office Equipment & Supplies
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Mar 09, 2009 | Toshiba E-STUDIO 550 Copier
Toshbia estudio 600 error code CD20
This is not an easy procedure. Most likely, the auger is stopped up with chunks of hardened toner, which is prohibiting the auger motor from turning, thereby causing your code. You are going to have to take the main board off, as well as the metal tub that the board is mounted in to remove the auger. Once these are off, you will be able to see how it comes off. If you need more info, let me know.
hope this helps,
C
Sep 23, 2008 | Toshiba Estudio 200L Copier
Konica 7020
F26-1 at power up. [Description] F26-1 at power up.
[Solution]
PROBABLE CAUSES:
1. The TDS (Toner Density Sensor), in the developing unit, has detected a depletion of toner.
Note: This may have been caused by the customer making an excessive amount of copies while the machine was out of toner. It may also be caused by a bound toner addition system.
Clean all toner from the toner recycle and toner supply assemblies. Confirm that the gear mesh between the toner supply auger drive gear and toner supply motor (M4) is flush. If toner supply conveyance is normal and the toner cavity is empty, install a new toner cartridge (Item #950236) and then perform the following diagnostic mode to replenish the developing unit with toner:
a. Access the 47 mode (power the copier ON while pressing the 4 and 7 keys).
b. Enter output code 54.
c. Press the START button.
Note: Toner will now be added to the developing unit and stop automatically when target level is reached, although it will not run any longer than 3 minutes.
d. Power copier OFF/ON to return to normal copy mode.
Note: Perform the following 25 mode software switch settings to minimize the amount of copies that can be made, prior to copy inhibit, when the ADD TONER message is displayed:
- Access the 25 mode (hold down the 2 and 5 keys at power ON).
- Select [1] (SOFTWARE SW).
- Using the up and down arrows, scroll to the following software switches and set them as follows:
a. 4-0 set to 0
b. 4-1 set to 0
c. 4-2 set to 0
d. 4-3 set to 0
- Power OFF/ON to return to normal copy mode.
Notes:
A. These setting will allow the ADD TONER message to be displayed immediately and only allow 100 copies to be thereafter.
B. Copier inhibit will automatically be released when a new toner cartridge is installed.
2. The toner conveyance gear is worn. The toner conveyance gear is driven by the toner supply motor located on the toner supply unit.
Replace the toner conveyance gear (p/n 26NA32680).
I may be able to get the manuals for a nominal charge. bkbell@brianbell.net
Nov 20, 2007 | Konica Minolta DiALTA Di200 Copier
44 people viewed this question
k24674
jasbo
jasbo
