Question about Shoprider Sunrunner 4 - 4 Wheel Scooter
Batteries discharge too fast could ignition switch be a problem?
    Problem Solver:
  • 17 Answers
No, but batteries could be shot.
Posted on Sep 22, 2009
12.000 mi.- when hot it idles at 2,000 rpm. after being turned off hard time starting.
Hi, Frank for hard starting the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery nearly discharged, should have 12.5 volts.
4. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.*
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.*
10. Enricher valve inoperative.*
11. Engine lubricant to heavy (winter operation).
12. Ignition is not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
* Carbureted models.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Wildgoose Chase Moto Guzzi
Griso Fast Idle Also switching from metric to US
http://www.guzzitek.org/gb/ma_us_uk/1100/Griso1100_022007_Atel(GB).pdf
Apr 20, 2016 | 2007 Moto Guzzi Griso 1100
93 Geo Storm standard Transmission 1.6 Engine Lately I have to push start it Replaced ignition switch Checked all the fuses Starters good Help 48 disabled female
bad fuel, is it old? fuel.
needs tuneup, air cleaner and spark plugs , at least.
if the starter cranks fast and dont' start,
but does push started. that means the spark is weak
when cranking, and marginal spark plugs can do that.
this car is really (under Geo snake skins) a
an Isuzu Impulse
and Isuzu is defunct there too. (double bad)
now my real guess......analysis...
im not sure your order stated.
the engine would not crank over with a key before the new switch or after?
and "starters good", does that mean , it still fails to crank start with key
but the hot wiring of starter does?
try this:
tell use what happens when you turn the key, is best.
I turn the key, and i get the dash board to light up,
lots of lights. and the CEL LaMP GLOWS.
the CEL lamp, means the ENGINE brain is alive.
then you turn the key to cranks (start) position.
  1. nothing happens.
  2. it only clicks
  3. it cranks slowly,
  4. it cranks fast, just like a new car does. fast. cranking.
1,2,3,4.?
and does jumper cable starts work>?
if this works , your battery is low. , discharged or dead, or bad.
if the battery keeps going low, its bad, or the alternator fails to charge the battery, or you have phantom drains , discharging it as you sleep.
my guess, (based on most common)
is #3, slow cranks, and spark plugs are long since gone.(fouled and gaps no longer in spec>)
Nov 01, 2014 | 1993 Geo Storm
Battery ok no ignition
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a posible prime suspect please visit the webside below:
Harley Diagnostic Trouble Codes
Good luck
Mar 21, 2014 | Harley Davidson XLH Sportster 883 Hugger...
Neutral light and headlight don't work
Jan 07, 2014 | Harley Davidson XL 1200 C Sportster Custom...
Xperia 8 e 15 i battery get discharged fast
REMOVE THE BATTERY AND CHECK WHETHER THE BATTERY IS SWOLLEN IF SO CHANGE THE BATTERY
Dec 25, 2013 | Sony Ericsson Xperia X8 (E15I)
Why battery fastly discharging
the problem with the battery discharging fastly could be as simple as needing a replacement battery. if this is not the case then there should be a power save function on the phone, also having the volume loud, the screen bright and the vibrate function on are also contributers
Aug 04, 2013 | Cell Phones
Recently changed lock cylinder on a 97 jeep wrangler and airbag light came on. Why?
DID YOU REMOVE AIRBAG FUSE OR DISCONNECT NEGATIVE BATTERY CABLE TO DISCHARGE AIRBAG CAPACITOR DISCHARGE BEFORE YOU REPLACE IGNITION SWITCH KEYLOCK CYLINDER. CHECK MAKE SURE YOU INSTALLED AIRBAG FUSE OR IF YOU DID DISCONNECT NEGATIVE BATTERY CABLE.WHEN YOU RECONNECT NEGATIVE BATTERY CABLE.WITH IGNITION SWITCH ON POSITION FOR MINUTE THE AIRBAG LIGHT SHOULD TURN OFF.IF NOT HAVE GARAGE OR DEALERSHIP CODE SCAN AIRBAGS SYSTEM SEE WHAT CAUSE SRS AIRBAG LIGHT TO FLASH ON COULD HAVE FAULT IN SYSTEM..
Nov 08, 2011 | 1997 Jeep Wrangler
Wont start turns over but no start
1 Inspect Battery Battery Discharged or Faulty. 2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable. 3 Inspect Fuel Filter Clogged or Dirty Fuel Filter. 3 Inspect Distributor Cap Distributor Cap Cracked or Burned. 5 Inspect Coil - Ignition Faulty Ignition Coil. 6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 8 Inspect Starter Starter Motor Faulty. 9 Inspect Fuel Pump Low Fuel Pressure. 10 Inspect Solenoid Switch Faulty Starter Solenoid Switch. 11 Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay. 12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator. 13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 14 Inspect Starter Drive Faulty Starter Drive. 15 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat. 17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC. 18 Inspect Fuel Tank Fuel Tank Empty. 19 Inspect Carburetor Carburetor Flooded or Faulty Choke. 20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
Jul 02, 2009 | 1997 Ford F250 SuperCab
92 toyota previa battery discharges
bad ignition switch. replace and recheck
Jan 26, 2009 | 1992 Toyota Previa
Seems battery being drained
Q1. Engine will not start or is hard to start (Cranks OK) A1 -Ignition lock switch faulty -Ignition coil faulty -Power transistor faulty -Spark plugs faulty -Ignition wiring disconnected or broken -Spark plugs faulty Q2, Engine will not crank A2. Battery discharged Battery cables loose, corroded or worn out Transaxle range switch faulty (Vehicle with automatic transaxle only) Fusible link blown Starter motor faulty Ignition switch faulty Ignition lock switch faulty REMEDY Charge or replace battery Repair or replace cables Adjust or replace switch Replace fusible link Repair starter motor Replace ignition switch Replace ignition lock switch
May 20, 2008 | 2000 Hyundai Accent
Shoprider Sunrunner 4 - 4 Wheel Scooter Logo
109 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
