Question about Maxent MX-42HPM20 42 in. Plasma HDTV
I HAVE THE TV AS A COMPUTER MONITOR AND THE RESOLUTION IS WRONG. IF I TRY TO MAKE THE RESOLUTION DIFFERENT THE SCREEN TURNS BLUE AND I CANT SEE ANYTHING THE RESOLUTION ID 800 X 600 AND I CANT ACCESS SOME WEB PAGES BECAUSE OF THIS
Pic is blue with white lines going through it
Posted on Oct 09, 2009
    Sergeant:
  • 217 Answers
If you are trying to change your Graphic Card resolution try this.Right Cilck anywhere on your desktop screen,You should get a Display Menu Box.Click on properties and then settings.You can now slide the resolution bar to 1024 x 786 click apply then OK your resolution will change and ask if you want to keep this setting if you got a display click yes.Remember to make sure your TV supports this resolution.Good Luck.
Posted on Sep 11, 2009
LG HDTV Monitor Permenantly switched on but no display white screen with V.2.0.0 moving around the screen
sounds like you are possibly over resolution (setting resolution higher than the monitor can show. Try setting to low resolution and see if it shows up. Try VGA first and move up if it shows.
Jun 21, 2014 | LG Flatron N1910lzbf 19 Led Lcd Monitor 43...
When i go to pc mode on my aquos 42 inch the background and screen is blue not the blue screen of death the set is 2 yrs old
That sounds like a resolution problem. If you have a PC attached to the TV, unplug the monitor cable, and plug a computer monitor to the computer. Change the resolution down to 1024x768, then try plugging back into the TV
Jan 12, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hello, well I hooked up my computer to my vizio with a vga cable. At first it worked just fine, then once I tried changing the resolution for a video game, the screen went blue and says "not...
The VGA cabel has vast signal capacity. However, the computer to has as much sigal cacity. The TV also has as much signal capacity as well. The computer in this situation is providing the signals to all devices connected to the insfrusture. However, the computer has a functionality requirements mode. For exaomple, the computer blankout whenever resolution is increased is n consideration of requirng so much power supply for all displays on several powerfun screens of much high defincition capapacity. The more high definition the computer, the possibility of powering signlas to TVs of much least intensity not vise verser.
Jan 11, 2011 | Computers & Internet
I reset the resolution on the computer (big mistake) and now I cant see the screen in order to reset it back. The screen turns all blue with two messages and a flash of the windows screen (windows 7). The...
Boot up in safe mode and selct VGA support, then set the video resolution to your Princeton VL2018 native resolution mode (1680x1050 @60 Hz)
See more here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Hopefully you monitor doese not have the same problem (bad caps) just like the other VL2018 as shown in my pictures here (but it will fail for sure later on):
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Jun 12, 2010 | Princeton Digital VL2018W Monitor
Hey my monitor turns on but than turns black after a few seconds? What can be wrong with it?
Most monitors turn blank after a few seconds if they are not receiving a signal from the computer. Check the graphics cables and try another monitor if you have one. If neither works, then you have a graphics card problem.
Dec 28, 2009 | HP f2105 Monitor
HPW2338h goes black after about 3 seconds. Push power button on, it turns on and then black after 3 seconds. Power light on monitor stays on.
hi,
you can try to change the screen resolution with a spare monitor to a different setting, usually higher 1024X768, then unplug the old monitor and then plug in the flat screen. try different resolutions untill it submits. if you cant get it to run on your machine, take it to another computer and see if you can get it to run on that. if it wont run on either then you have a problem with the monitor. pawn shops usually have flatscreens for way cheaper than new..
jm
Dec 15, 2009 | HP w19 19" LCD Monitor
LG stuck in powersave mode
Connect it to a different computer, e.g., a notebook computer,
and set the screen-resolution to 800-by-600, and see if the monitor works.
Change the screen-resolution to 1024-by-768, and try again.
Change the screen-resolution to 1280-by-1024, and try again.
Connect a different monitor to your computer,
and set the screen-resolution to 800-by-600.
Then, disconnect the "alternate" monitor, and connect your monitor.
Nov 25, 2009 | LG W1942TQ-BF 19 inch Monitor
My Computer turns on but my monitor doesn't. HELP !
boot up the computer in safe mode and see if the monitor works on a really low resolution. if it does maybe the resolution of the computer was unsupported by the monitor. up the resolution gradually or find out the optimal resolution for the screen
Oct 02, 2017 | Acer AL1714MS (Silver) 17" LCD Monitor
Trying to use tv as computer monitor screen says not supported
You need to get into ur computer settings and change the screen resolution, change it to a lower value. try 800 by 600
Mar 26, 2009 | Televison & Video
Pc and lcd tv
that's really easy. just plug in a VGA or DVI cord from the PC to the Sova TV (those are both regular cables that normally would go the computer monitor). then press the source button on the remote (not too fast, it takes a second to detect the signal), until you see VGA or DVI, and your computer screen should show up. use the display settings on your computer to get the best resolution on the tv. depending on your computer, you may have a program that can save different screen resolution profiles for you (since the Sova TV resolution and the computer's optimized resolution using a different screen (such as the built in screen on a laptop -- or a different monitor with better resolution than the Sova TV), this way you can easily toggle between settings depending on what monitor you use.
Jul 29, 2007 | Sova DSV32P112 32 in. LCD Television
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
239 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
