Question about Kenmore Elite 21086
What does LD mean when it flashes on the timer placement?
  • 574 Answers
Long drain
Posted on Sep 11, 2009
Keep getting error code Ld what does this mean
Ld (F32) Long Drain "Ld" flashes when water level drop ain't sensed by the control.
Check these things out:
Drain pump fouled/clogged
Drain hose too high for proper pumping.
Pressure hose tubing clogged/pinched came loose from that fancy control upstairs.
Post your model number I might have a service manual and a better answer for you.
Jun 22, 2011 | Washing Machines
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
The machine won`t wash and the letters LD are appearing in the timer slot ?
Hello there:
Ld Long Drain Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. unplug the POWER cord .or turn off the maching for 10 min and retry if this stil does not help check each of these things i have mentioned below and replace or repair as needed
· Check wiring harness
· Check pump motor
· Check circuit board
Sep 26, 2010 | Washing Machines
My washer stops in the middle of the cycle what does this mean Flashes LD Error
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does the code Ld mean???
Ld flashes when the water level does not change after the drain pump is on. ? Is the drain hose or the drain pump clogged? ? Is the drain hose height greater than 96′?
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does "Ld" mean?
Ld
Long Drain
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
What does LD mean?
It isn't whether the water drained out, it is how quickly the water drained out. Common causes of the LD or long drain fault code are a kinked drain hose or some article of clothing being caught in the pump suction hose and increasing the time that it takes for the water to drain. It has to do with the cycle timer. I would look for some sort of obstruction. Also check the pump impeller for broken/missing blades and that it spins freely. If not, the pump is defective. Hopefully it is just a clogged drain line or pump. Hope this helped and best wishes.
Aug 23, 2009 | Washing Machines
What does LD mean in the LED time screen? it fills for a min then stops and flashes Ld
Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Jul 28, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
147 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
