Question about Classic Accessories Garden
I cant get the nuts off the blades on my cub cadet do you turn them l or r
The nuts turn left or counterclockwise to remove the blades. Spray the nuts and shaft with generous dose of lubricant. Place a block of wood between one of the blades and the housing to keep the blades from turning and use a box-in wrench with a two foot piece of pipe over the wrench to use for leverage.
Posted on Sep 11, 2009
  • 631 Answers
Not sure on your particular mower but most all mowers are left hand threads so you would loosen like you are tightening normally. I hope that is clear to you. lol
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Cub Cadet zero turn. Cannot get the blades to turn when PTO switch is pulled. Belts are fine and attached. Please help. John
i had the same problem. there was a short in the relay just before the wire gets to to back pulley assembly.
Apr 28, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
I have a cub cedet commercial tank 60 zero turn lawn mower, and i need to change lawn mower blades. Which way should i turn the nut to take the blades off.
As viewed from the bottom, if the blade turns clockwise, then the bolt should have a left-hand thread. A possible exception would be if the blade cannot slip relative to the shaft. This could be the case if the blade (not the washer) has a D shaped hole in it.
Good luck, Al K
Aug 26, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Sounds like a blade is hitting something on my Cub Cadet LT 1042.
with tractor off and key in pocket check blade for straightness if straight then check by moving it up down if loose check retaining nut if nut tight then possible mandrel bearing burnt or shaft bent also check the mandrels are bolted correctly to deck lastly but least likely is a bent deck
May 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
CUB CADET ZERO TURN Z-FORCE 3-BLADE CONFIGURATION
Under each blade is one single nut holding each blade on. It is not left-hand thread and there is nothing special about it.
Standard thread - Standard hardware - Standard tools. (If memory serves, you need a 15/16" socket to remove these.)
There is no need to index or time the blades. They cannot hit together unless something is bent or damaged on your mower deck.
Hope this helps,
Dolf-
Oct 14, 2009 | Garden
Garden Logo
113 people viewed this question
Top Classic Accessories Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Classic Accessories Garden Expert? Answer questions, earn points and help others
