Question about Dell Dimension 4600 PC Desktop
2 inch black on both sides of the monitor (Horizontal)
Good day. i need help on my monitor hansol.i my horizontal adjustment cannot fill the entire monitor leaving about 2 inch black on right and left of my monitor. if i adjust the resolution to high it make about 5 inch both of the sides. if i am in the dos mode, it is only about 2 inch both sides if i use higher refresh rate in the windows environment, the black color becomes larger. what happen to my monitor. I was in notebook in my documents when all of a sudden I had less screen. The screen is black about 2 inches on both sides. So far all I've done is do a system restore but that did nothing to solve the problem please help me. my e mail address is lee5@fuse.net. thanks, bjreese
  • 23 Answers
Hi Bj, Is it an aftermarket video-card? If it is, like ATI or Nvidia, Download the recent drivers for your particular card, Uninstall your Videocard from device manager, then install the software.
CoDoc
Posted on Dec 10, 2007
Acer laptop monitor doesn't stretch all the way horizontally
Try adjusting the screen resolution to 1024 x 768 or higher.
Aug 21, 2012 | Acer Computers & Internet
In 2004 I bought a monitor Hansol 930 D model, (model no.D19BL, s/n A23490411020263) Since 2011, horizontal image began to narrow, now horizontal image H-size is 210 mm. vertical image size is ...
The horizontal deflection coil is shorted. There is no way to fix that, the entire tube would have to be replaced and that would cost as much as a new monitor.
Just buy a second-hand LCD monitor from here
http://www.diabloscomputer.ro/monitoare-second-hand-fujitsu-siemens-p19-2
Asta l-am luat eu si are o imagine excelenta.
Jul 01, 2011 | Hansol Europe 930D 19" CRT Monitor
My new LG Flatron E2350 does not fill the 23 inch screen only 22 inches with a black border, have updated graphics and monitor card to the latest. What do I need to do for the graphics to fill the 23 inch...
Similar to TV - you need to adjust the "H" - Horizontal and "V" - Vertical. Horizontal will move picture up or down and Vertical will adjust left to right.
Use the menu button on your monitor.
Apr 03, 2011 | LG Flatron L1515S 15" LCD Monitor
Picture will not fill entire screen, what do I do?
Try to adjust youre size with monitor? Should be a menu or adjust button on your monitor. Then you can extend vertical and horizontal sike. Good Luck
Nov 22, 2009 | Compaq Presario 1200,1600, Series CD...
There is a black 2 1/2inch bar on leftside of screen how do i adjust is?
if your lucky it's just your H-center is off tilt. to check this Press the menu button on your monitor. scroll through the options till you see Horizontal-center option. select this setting and move the screen to the left. The entire screen should start shifting to the left and fill in the screen. now if you do this and you get a black bar on the right. Center the screen where you have the same amount of black on both sides of the screen. scroll through your menu till you see the H-size. increasing this will fill in the black area. Hope this helps.
Sep 13, 2009 | X2Gen MG19MY 19" LCD Monitor
Black on two sides of monitor
sounds like the monitor is going or the horizontal control isnt adjusted fully.
Jun 14, 2009 | HP Compaq by Pentium III 1GHz Desktop PC...
Black at left and right of monitor
Since this is a CRT monitor, it doesn't have a native resolution like LCD monitors. You need to adjust the veritcal and horizontal sizes to fit the monitor. On the front of the monitor there are some menu buttons. You need to open the on-screen menu, then navigate to the Horizontal Size and Position menu, use the plus and minus buttons to grow and shrink the image. If it's not centered, use the Horizontal Position menu to move it around. Use this same system for the Vertical menu and you can get your image to fit your screen. By the way, you should have your operating system running with a white (or light colored screen) up when you do this so you can see all the edges of your desktop. The buttons are tricky, but they kinda make sense. Good Luck!
May 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
19" hansol 920p monitor
To my knowledge, it is not the zoom that has to be adjusted but rather the horizontal width, zoom would expand all (to, bottom & both sides) whereas your only concern are the two sides.
Should the horizontal width not fully expand, then there is an internal problem with the horizontal deflection circuitry which could either be the yoke, a capacitor or shunt diodes. In certain instances, a below normal voltage at the mains or the internal power supply could also cause this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Hansol Multitech 920p 19" CRT Monitor
1 it is due to horizntal output trnansistor. 2 capacitor connected to horz output. 3 flyback transformer. hope this will help you.
Oct 08, 2007 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Dell Dimension 4600 PC Desktop Logo
80 people viewed this question
Alun Cox
