No paper fed reload paper
No paper fed reload paper comes up while trying to print. Paper tray is full. Do not see any obstructions.
    Problem Solver:
  • 16 Answers
The paper detect sensor could have dirt in it. Blow canned air directly on the sensor and try again. Asides from the sensor being bad the actuator for the sensor could be broken.
Posted on Sep 11, 2009
I have a Brother model HL-2040. The printer was working fine. I put some additional paper in it and clicked print and all the lights started flashing. I looked for a paper in the printer wrong and...
Red paper light is on means that there is no paper fed in the machine. Follow the steps below to clear this issue:
- First remove the paper tray from the machine. - Then remove all the paper from the tray. - Fan the paper well or run your fingers through the edges of the paper. - Adjust the paper guides of the tray. - Then reload the paper back to the paper tray. - Put the paper tray back to the machine. - Lastly press the go/blue button.
Printer should print the document.
Hope this helps. Rate if it works. Thanks
May 09, 2011 | Brother Office Equipment & Supplies
H2 error when printing from pdf to A3 in multipurpose tray
H2 error code means that the paper size you are feeding into the machine does not match the paper size programmed into the machine. Minolta's are picky about these 2 size matching. So if you trying to print onto A3 then when you select the multipurpose tray it must read as A3.
Here is the info from the factory service manual:
H2 The length of the paper set does not
match that of the paper actually taken
up and fed in.
• Load paper of the correct size again
according to the set paper size.
• Turn OFF and ON the Power Switch.
• For copier tray: Slide out and in the
paper tray in which the size error has
occurred.
• For Manual Bypass Tray: Place paper
in the Manual Bypass Tray.
• For Multiple Bypass Tray: Unload
paper from the Multiple Bypass Tray,
then reload it back again.
Nov 23, 2009 | Minolta Di152 Laser Printer
Paper feeds, but won't print. As far as I can tell there is ink.
Ensure the Paper Tray is Not Overfilled Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray Adjust the Printer Paper Guides Adjust the paper guides to fit the size paper being used (Figure 1). The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides. Locate and Remove Any Obstructions Inside the Printer and Input Tray Open the front cover and make sure the kickstand (if there is one) is engaged. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects. Close the cover. Remove all paper from the input tray. Inspect the input tray for any obstructions. Remove any visible obstructions. Reinsert the paper. Determine if Multiple Sheets Are Fed at Once From the Paper Tray or ADF Determine if multiple sheets are fed at once from the the paper tray or Automatic Document Feeder (ADF). Verify the print media installed is compatible with the printer Clean the ADF Paper Feed Roller Disconnect the AC power from the printer. Open the cover of the Automatic Document Feeder (Figure 1). Figure 1: Raise the Cover of the Automatic Document Feeder Using a damp paper towel, gently wipe the rubber roller to remove any ink or paper debris (Figure 2). Figure 2: Paper Feed Roller on the Automatic Document Feeder Close the cover and reconnect the power. Reseat the Dell Printer Power Adapter If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a Dell? inkjet printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends. If the printer queue icon is showing in your system tray (by your clock), you may have documents that are paused for printing. To resume printing a paused document: Double-click the printer queue icon to check document status of the active printer. Right-click on any documents that show Paused under Status, and then click Resume in the drop-down menu. Try a Different Type of Print Media Many image quality and paper feed issues are caused by the type of print media being used. Try a different type of print media that is specifically made for this printer. Replace the printer.
Nov 22, 2009 | Dell 968 All-In-One Printer
PAPER WILL NOT FEED
hi there !
you may do the steps below:
-Ensure the Paper Tray is Not Overfilled
-Adjust the Printer Paper Guides
-Locate and Remove Any Obstructions Inside the Printer and Input Tray
-Determine if Multiple Sheets Are Fed at Once From the Paper Tray or Automatic Document Feeder (ADF).
-Verify the Print Media Installed Is Compatible With the Printer
-Clean the ADF Paper Feed Roller
-Reseat the Dell Printer Power Adapter
-Try a Different Type of Print Media
*If all else fails
-Replace the Dell Printer
cheers!
Oct 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
Have a canon mp 470 keeps having a error of load paper in tray and it is full
Try removing the tray, reloading with the paper and reinserting the tray into the computer. If the paper is loaded a little unevenly, or if the tray is not fully inserted - or if there is an obstruction in the tray tracks, it would give you that error.
Oct 11, 2009 | Office Equipment & Supplies
Extra paper being fed after print job
Try a test page from the control panel, if this works properly you probably have an issue with the software of the printer. Reload the printer as if it was a brand new machine.
Jun 03, 2009 | Brother HL-2070N Laser Printer
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
Paper jam
Some of the Ink Jets have a cover in the back of the printer that you have to turn a lock to remove and you could have some paper stuck back there.
Mar 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
I have a brother copy/fax/print MFC 5860. i am unable to print. no paper jam..the screen reads: no paper fed #2. reload paper, then press start. i have paper in both paper trays and have autoselect...
lower paper feeder is out of position. you have to open the printer and get to the lower paper tray feeder. push the plastic gear wheel and axe into position again.
May 15, 2008 | Brother Office Equipment & Supplies
Brother MFC-8460N ... No Paper response
I had the same problem with a customer, to resolve this issue:
> Go to the printers folder
> Right click on the printer
> Go to printing preferences
> Under the paper source settings change it from autoselect to Tray1 and save the settings.
This will force the printer to print to tray1.
That fixed it for me, hope it works for you too.
Sergio Mayorga
Technical Support Representative
SACA Technologies, Inc.
Jun 16, 2007 | Brother MFC-8460N Laser Printer
176 people viewed this question
k24674
