Question about Canon Office Equipment & Supplies
We have a Canon PC 400 copier. When making a
We have a Canon PC 400 copier. When making a copy, there are black spots on the copy every 4 inches on the edge of the paper. The toner is fairly new.
    President:
  • 1,126 Answers
Remove the toner/drum cartridge. Carefully rotate the drum, via the end with gear, to check the edges for toner spots like appear on the copies. If located on drum, GENTLY wipe off with a dry cotton ball. Reinstall cartridge. Check to see that spots are gone. If spots reappear, replace with new cartridge (drum most likely damaged)
Posted on Sep 11, 2009
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
My ir 400 gives a white spot
something could be blocking the primary chargeing corona wires/roller. i see it a lot on the ir 5000 when the primary corona assmbly cleaning pads get stuck half way through the cleaning cycle.
Jun 16, 2010 | Canon imageRUNNER 400S Copier
We are getting spots of toner on our copies.
Vacume the interior of copier, check the drum.If there is spots on drum, change the drum.
Also check the fixing section.
May 25, 2010 | Canon PC-940 Black and White Copier
Why spot in the copy? ir 400 canon
If its black spots on the copy it could be that your drum unit needs to be serviced or change. IF it's white spots it could be a problem with moisture in the paper. IF it is moisture doing a copy on the back side of the paper should come out clear.
Jan 21, 2010 | Canon imageRUNNER 400S Copier
I have a canon pc 300 that makes black spots every inch on the right side of the paper about 3 inches from the edge...if I lighten up the slider you can barely see the spots, but the writing is also...
You can actually turn the drum by hand and look for the spot. If not there a glob of toner on the upper fuser roller would give you the same effect.
Jan 05, 2010 | Office Equipment & Supplies
I am own a canon IR 400 copier printer. it is persist of black copy for xerox. but printing is alright please solve my problem
Hello sir; When you make a copy, lift up the cover check the exposue lamp is on, if not replace it.
Aug 02, 2009 | Canon imageRUNNER 400S Copier
Don't know how to make a copy
yes you are suppoused to put the original in the platten-glass an dthe push the green button that means Start copying. and yeah the copier must have paper on the right side.
Jan 24, 2009 | Canon PC-400 Color Copier
Canon Imagerunner 400 S
plese send m/c model number
Jan 12, 2009 | Canon imageRUNNER 400S Copier
Refurbished Canon PC 160
Yes...it's definitely the toner cartridge.
Erice
Oct 29, 2007 | Office Equipment & Supplies
117 people viewed this question
old marine
old marine
