Random keys on my laptop quit working intermittently, any suggestions
    Problem Solver:
  • 6 Answers
Get some canned air from the electronics or office supply store (I think even Walmart in the electronics dept)
Turn the laptop OFF. Now open it but then turn it on its side - the keyboard will be up & down instead of flat. Take the canned air and spray into the keypad, sweeping from top to bottom.
Now turn it back upright & turn it on. Little pieces of dust get under the keys sometimes and prevent things from working right, so repeat as needed.
Posted on Sep 11, 2009
  • 4,806 Answers
If the problem is intermittent then the problem could just be foreign objects like crumbs and hair that's trapped under the keys.
Turn the laptop off and stand it on it's side with the lid open. Get a soft, dry paintbrush and brush the keys, gently tap the keyboard in various places with the back of the paintbrush to help dislodge anything that's trapped.
Once your satisfied all the keys are clear turn the laptop on and see if it has made any difference.
Good luck.
    Problem Solver:
  • 16 Answers
If any specific key is doing this then take off the key and press the rubber piece with your finger to test the connection without any mechanical interference. Failing that you are sure the button is pressing correctly open the laptop and reseat all keyboard connectors prior to keyboard replacement.
I have a 2000 Dodge Stratus with a random misfire on 1,3 and 5. The engine runs fine besides a twitch in the motor that can be felt while idling. Already replaced plugs and wires. Suggestions?
get the OBD codes read this will tell you which switch/sensor is causing the issue , the last random misfire i encountered turned out to be low cylinder compression so if the OBD code says " random misfire " then get the cylinder compressions read , hope this helps
Apr 08, 2015 | 2000 Dodge Stratus
A/C not working
sounds like you have a leak, o-rings
Jul 20, 2012 | 1998 Chevrolet Tahoe
Hi I have a Grundfos pump which both my showers run off. It has been working fine for a year but is now intermittent...it is ok for the first shower of the morning and then cuts out...it works very...
Hi Hayley.
Please allow me to try to help you.
Random water pumping or intermittent water pumping, appears to be quite a commonality with the Grundfos pump. The solution to this is quite a bit of process, the details of which you can get here...
http://inspectapedia.com/water/Intermittent-Water-Pump-Cycling.php
I have also attached a video, trust that gives you a bit more insight.
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | Grundfos Plumbing
Sander motor just quit running sarted up again then quit again won't start
I would take a lok at the switch, sometimes they become full of dirt and make intermittent contact
Jan 12, 2011 | Porter Cable 332K Quicksand Random Orbit...
Laptop keyboard not working
Usually in my experience most laptop keyboards are disposable. I have 2 suggestions for you.
1. buy a new same brand keyboard.
2. remove the flex connector, then use an external usb keyboard, or a bluetooth wireless keyboard.
hope it helps your problem.
Jan 03, 2018 | Acer TravelMate 5602WSMi Notebook
03 pontiac ,fuel quits intermittly
fuel pump maybe shorting out.. may have bad ground
Apr 26, 2010 | 2003 Pontiac Sunfire
Beeps
This is normally a indicator that key is stuck, or multiple key strikes on the keyboard. It could also be an intermittent problem. Either way, this isn't something to get overly concerned with, unless it gets worse.
Aug 15, 2008 | Dell XPS M1530 Laptop
Remote problem
It sounds like an intermittant Infared sensor problem or there is an intermittant solder connection between the sensor and the controler chip. Good Luck
Apr 08, 2007 | Kenwood VR-407 Receiver
Computers & Internet Logo
256 people viewed this question
David Payne
David Payne
