Question about Humminbird Boating
Is there any way to test the transducer used on my depth finder?
hydetech
  • 113 Answers
SOURCE: Replacement of an old Impulse QT206
I believe it is the same model. Even if it is different, it will probably work if it has the same type of plug.
Posted on Jul 24, 2008
  • 5 Answers
SOURCE: Raymarine St40 trouble
50/200 combination will work fine but 170/200 may be a little close in frequency and give you some trouble. "May be OK" doesn't leave me with a lot of confidence.
  • 18 Answers
SOURCE: wire on depth finder has been piched, can tou
Yes, you can. I have done it several times. Keep the separated wires fairly short. You can pick the braided (shield) wire apart with a pin or such.
Posted on Jun 18, 2009
SOURCE: Marine Faria depth finder, with thru the hull transducer.
I'm having the exact same problem. I spoke with the service manager at Faria (Ted) and he was thinking that as long as the gauge is showing a reading, it should default to reading the depth. I'll probably send the guage in to FARIA - they'll repair it for $55. You bring up a good point - maybe the transducer is bad? I put a call in to the Tedmeister to see what he thinks. I'll post if he sheds any light.
Posted on Aug 18, 2009
juandiablo
SOURCE: lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Posted on Sep 19, 2009
Can a cable on a depth finder be spliced
it can but will not work like a new one . . .they don't cost that much why splice it back
Feb 16, 2013 | Boating
Best way to clean depth finder transducer
There are many websites that can tell you how to clean your transducer.
Check the link below.
-Steve
clean depth transducer Google Search
Aug 25, 2012 | Uniden Qt206 Thru Hull, Digital Depth...
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
My Garmin depth finder/gps combo is giving me a false depth reading,like way way outta sack,not a foot or two. It came as an extra on a boat I purchased and elsewise seems ok,just inaccurate depth. Is it...
YOUR TRANSDUCER MAY BE SET FOR HORIZONTAL MODE...MEANING FROM BANK TO BOAT, NOT DEPTH...CHECK THE TRANSDUCER TO MAKE SURE, IT IS AIMING DOWN, NOT OUT...OTHERWISE YOU'LL NEED TO CHECK YOUR MODE SETTINGS IN YOUR MENU.
YOU CAN ALSO DO A TEST ON YOUR TRANSDUCER, BY SCREWING IT ONTO A BROOM STICK ...ADJUST THE TRANSDUCER DOWN, CHECK YOUR SETTINGS ON THE SCREEN, THEN DO A SIDE TEST WITH THE TRANSDUCER TILTED SIDEWAYS TOWARDS THE BANK AND CHECK YOUR SCREEN!
THEY CAN BE TRICKY...AND ARE VERY SENSITIVE, BUT ONCE YOU FIGURE OUT, HOW YOU WANT TO USE IT, YOU'LL LOVE IT!
HOPE THIS HELPS!
Sep 03, 2011 | Garmin GPS
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
My fish finder isn't showing depth or temperature anymore. I was fishing one day and my temp started blinking and went away, then my depth began blinking and went away. Soon after this my screen wasn't...
Yes... or it is unplugged... or the wire is broken...
Typically you hear a clicking sound at the transducer when it is powered and running but in your case all function is missing from the display and temp and depth is off of the transducer..
Sep 04, 2017 | Humminbird Fishfinder 550
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
Lowrance depth finder missing adapter cable
Jul 28, 2009 | Boating
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Jul 27, 2009 | Minn Kota Maxxum 70 Universal Motor/Sonar...
Boating Logo
85 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
