Question about Car Audio & Video
Installed a pioneer deh-p6500 and now i have no sound other than when i touch the speaker wires to the wired jack coming out of the back of the radio and then i can just barely hear it
Another possible problem was what happened to me. When I wired it into the car harness, I attached the YELLOW/BLACK wire......this is a cellular mute attachment, so if there is connected, the pioneer thinks you are receiving a cell call and mutes the system. Make sure this wire is not attached to anything.
Posted on Nov 05, 2009
  • 22 Answers
YOU FRIED THE MOSFET POWER AMPLIFIER...SORRY!!!!
Posted on Sep 11, 2009
Power but no sound help plz....
well here we go how do you have your pioneer radio connected .
did you run the radio speaker wire out to the factory speaker or did you have an amp connected to the rca output jacks.
1 well if the radio connect by the speaker wire out the
output chip in the radio is fried and needs repair ....
2. if u have a amp connected to power your speakers for sound
check the amp to make sure you have power and no lose connection or speaker wires disconnected.
3. it also possible that the rca jacks are fried too
I no by experience that pioneer loses ground on the audio output jack (rca) well what we did to fix it is..
take and 18 gauge wire stripe back about 1/2" to 1" of the insulation to expose the copper wire and wrap this around the metal casing of the rca jacks and then ground the wire to a ground point do this for both left and right rca jacks...
radiorepair@windowtintingin239.com
Oct 30, 2013 | Pioneer DEH-P3500 CD Player
Whats colors go to which?
  • Connect each wire yourself if your were unable to obtain a wiring harness to install your car stereo.
  • 2
    Connect the positive wire from each speaker to the positive connector on the back of the stereo first. Then connect the negative wire from each speaker to the negative connector on the back of the stereo. If there is only one wire coming from the speakers, the speakers are grounded at the chassis. In this case you will need to install new speaker wiring.
  • 3
    Connect the ground (-/black) wire of the stereo to a screw or bolt near where the radio is mounted in the dash. Make sure the wire is attached to metal, not plastic or fiberglass.
  • 4
    Connect the 12 constant and ignition power wires (both +/red) to the new stereo. Refer to your stereo's installation manual to make sure these go to the correct places.
  • Read more: How to Install a Car Stereo ' eHow.com http://www.ehow.com/how_866_install-car-stereo.html#ixzz1C6OmWWNO
    Jan 25, 2011 | Pioneer DEH-P6500 CD Player
    I NEED A WIRE HARNESS FOR A PIONEER DEH-P6500, IS
    try pacparts.com. any good car audio store should probably have it
    also.
    Jul 22, 2010 | Pioneer DEH-P6500 CD Player
    Pioneer DEH-P6500 head unit doesnt turn on
    Check your radio fuse. It is likely if you didn't disconnect your battery terminal that you may have blown a fuse.
    About the speaker distortion, you may need to install filters to each speaker. They are not very expensive and can be found at just about any electronics store.
    Feb 26, 2010 | Pioneer DEH-P6500 CD Player
    XM radio portion just quick working..display on DEH-P6500 reads "antenna"..any things we can try out?
    No experience with this issue, but in your shoes I would check the satellite antenna connection into the back of the unit. From there, I would chase the wire and make sure it is not frayed. If that does not resolve or lead to a resolution of the issue, borrow an XM antenna and see if it will work then. If not, then something has happened internally with the head unit, most likely at the antenna connection jack.
    Jan 03, 2010 | Pioneer DEH-P6500 CD Player
    No sound from Pioneer DEH-P4600MP unit? Everything powers up and function,wires are installed correctly.
    check the speakers to see if they work. also check if the vehicle has an amplifier. if still no sound try to connect the radio directly with a speaker in the back with the wires that come with the radio. sometimes when one of the speakers in the vehicle is shorted out it will not sound. if you have tried all of the above and still no sound you might have a bad (ic) intergrated circuit. it is located on the back end of the radio. the aluminum piece is bolted on to it. just look where two bolts are at least an inch apart almost in the middle. the ic# is pal007a. that can be replaced with different model numbers like tda 7384 and so on.
    Sep 22, 2009 | Pioneer DEH-P460MP CD Player
    I installed pioneer deh-p6500 in my 1989 dodge ram van. it worked twice, third time i started vehicle, no sound! the display works, all the buttons work but if i turn the volume to max i can barely hear...
    it could be the rear wire harness come loose or if you have instellaed it yourself check all of the speaker (+) and (-) are connected and not touching any wrong wire. if still no sound get your radio checked for a burnt amp IC.
    Dec 22, 2008 | Car Audio & Video
    Stereo quit putting out sound
    if it was working, then stopped, it may be a grounded speaker or speaker wire. If a speaker is blown, you may have damaged the internal amplifier. It will need repair.
    You may have just hit a tone adjustment button like FIE or EQ where the settings at each frequency are changed based on the source you are listening to. If its not a big deal, pull the radio fuse and wait 5 minutes... or locate the reset button - usually behind the faceplate and start from scratch. This way you will know it wasnt a button pressed on accident
    Dec 22, 2008 | Pioneer DEH-P6500 CD Player
    Pioneer DEH-P2900MP head unit
    There is no power from the rca jacks. Option 1; connect the speaker wires directly. Any aftermarket auto manual (Hayes, Clymer) with wiring schematics will let you know what wire is what in the dash. Option 2; RCA jacks output to an amplifier. There is no power coming from the RCA jacks. They have to be used with the amp. If you chose to use the normal speaker wires, be aware that these radios do not like stock speakers or wire. If you take the time and money to replace all of it, the head unit will last much longer. If you choose to use an amplifier, it will burn out fast unless you replace the speakers and wires immediately.
    Mar 04, 2008 | Pioneer DEH-P2900MP CD Receiver...
    Cellular mute button
    The yellow/black wire at the back of the head unit may be grounded. Make sure it's not pinched or shorting on anything.
    Feb 27, 2007 | Pioneer DEH-P6500 CD Player
    Car Audio & Video Logo
    254 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
