Question about Frigidaire FRS23R4A Side by Side Refrigerator
Our refriderator is freezing stuff when it is set to a lower setting
  • 83 Answers
Turn down the freezer, for starters. Troubleshoot here: http://www.frigidaire.com/manuals.aspx
Posted on Sep 11, 2009
How do I set the temperature on a true refrigerator model GDM-26EM?
40 degree is a perfect temperature for produce if its lower that stuff will turn brown. Maybe you thermometer has failed. Go to the food store and get a red stick and put it in there. Then adjust with that temperature indication. Hope this helps and good luck.
May 09, 2014 | True Refrigerators
What temp should my heir refriderator b set on?
Whatever you like. If you like your milk super cold, crank the fridge up. The lower numbers will be more efficient.
Nov 27, 2013 | Refrigerators
Electrolux fridge temperature control displays a "square"
Try lower either the thermostat setting or the airflow control to the refrigerator to see if the temps are lowered.
Nov 26, 2013 | Electrolux Frigidaire Fridge Defrost Timer...
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Veg./ meat drawer items are freezing? Thermostat are set at factory suggested settings. What can we do to solve the problem?
factory suggested setting are just that "suggested" turn your thermostat down to a lower number, turn it down just one notch and see if tht solves the problem, if stuff still freezes, turn it down (lower number) more.
Mar 19, 2011 | Refrigerators
Hi: I have a 9yr old profile refrig, mod #tfx25prb...
What is your refrigerator cold setting? Try lowering the temp to to the medium setting.
Items in the lower part of the fridge will freeze if the setting is too high. (P.S. Cold air "sinks" so the lower part of the fridge will be colder. Cutting the "number" setting on the fridge does stop air flow though.
Oct 03, 2017 | Refrigerators
The filter and things in the fridge freeze.
You need to lower your settings if your stuff in the top of the fresh food side is freezing. If this does not solve your problem, you may have a damper door that is stuck open.
Mar 26, 2010 | LG LSC26905TT Side by Side Refrigerator
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
140 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
