Question about Zoom H4 Handy Recorder
I have a h4 recorder and when i turn it on i get a no card reading .changed card still same message
    President:
  • 1,137 Answers
Are you using the type of card recommended in the manual? There's also an update here that you might like to have:http://www.zoom.co.jp/english/download/software/h4.php
Posted on Sep 11, 2009
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Mar 25, 2017 | Zoom H4 Handy Recorder
Tip
When I turn on my Zoom H4n, it says no card
to solve this problem you will need a screw driver! disassemble the unit and reassemble, the card connectors some times they move if dropped
on Jun 06, 2011 | Zoom H4 Handy Recorder
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
Oct 14, 2011 | Zoom H4 Handy Recorder
The booting up screen says card protect. I don't know where the sd card lock switch is to release this.
The small SD cards have a tiny slide switch on the side of the card... it is TINY !!!
Jul 14, 2011 | Zoom H4 Handy Recorder
My Zoom h4 has been struggling for a couple months now. Most of the time I get either an error message concerning the card or saying the card is full. Even when the card has been reformatted both on my pc...
Make sure the batteries are good... some people try to use re-chargeable batteries and because of their lower voltage they cause problems. First thing is to try new batteries.
Feb 12, 2011 | Zoom H4 Handy Recorder
Zoom H4 recorder ver 1.30 says no card although card is inserted?
Hi. Not sure you still are in need of a solution but since my machine was doing the same thing last night, and I was able to solve it, I thought I'd post anyway.
For my machine, which has a more current OS than yours (mine is 2.20 I believe), I was receiving the same message after transferring material onto the computer. What needed to happen was to reformat the card. If you press "menu", the click on "file" you should have an option to reformat the card. It worked for me and it now works.
Hope that helps!
Sep 16, 2010 | Zoom H4 Handy Recorder
Not gettin to rec.
Take out the memory card, there is a little switch on it. One position is protected which means you can't record or delete anything from it, the other position is normal where you can record to or delete from.
Sep 27, 2009 | Zoom H4 Handy Recorder
Is there any way to reset the H4 back to factory settings? I adjusted levels and everythings out of whack now.
Hello.
Do you havce the manual to the H4? If not, I will provide you with a link to the PDF manual online. In thoroughly scanning thfe manual, there is no general reset function (in the manual, that is). It would be advised to call Zoom (who are very easy to work with) and ask them if there is a factory reset procedure which is not in the manual.
The manual for the H4 is very comprehensive, and there are default settings for many areas of the recorder. You could use this manual to reset your adjustments manually.
Here is the link to the manual:
http://www.samsontech.com/products/relatedDocs/H4_manual.pdf
Thanks for using FixYa
Aug 15, 2009 | Zoom H4 Handy Recorder
I am trying to install the Zoom H4 with Cubase LE4. Can't
Sounds like it's time you upgrade to a core 2 or better computer.
Jan 06, 2009 | Zoom H4 Handy Recorder
Can't connect the h4 handy recorder to a mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4  firmware from Zoom website
You will need an external SD card reader.
Good Luck
Nov 18, 2008 | Zoom H4 Handy Recorder
Zoom H4 Handy Recorder Logo
350 people viewed this question
Top Zoom Music Experts
Barry Webster
Level 1 Expert
patonplace
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
