Question about Frigidaire FMV156EM Microwave Oven
Same - the counter counts down, but doesn't cook.
Found out that if I lift the door slightly just the right way, it will cook and rotate.
  • 574 Answers
Yes your door isnt aligning right when closed and the lower interlock isnt being made when shut. Look and see if where the door pivots if it is broke or sagging down.
Posted on Sep 11, 2009
My GE counter top microwave will only count down. The light, fan, and turntable will not work. Lifting the door solution did not work. It's only 2 yrs. old.
I would suspect a door switch is defective or its mount is loose, misaligned, or broken.
See my he;p file on door switches here.
Dec 27, 2013 | GE Microwave Ovens
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
My microwave oven will count down but will not cook. If you lift up on the door handle it will start cooking. I can't see anything broken on the door. Is there an adjustment for the door? If so how do you...
There is no adjustment to a microwave door. But, your problem is that the door has been bent downwards a little causing the door not to connect inside. There is two things you can do , one, replace the microwave or two, try to found a locale appliance store and see if you buy a replacement door. It would probley be cheaper to replace the microwave.
thank you.
Sincerely,
Cat2868
Jan 28, 2011 | Frigidaire FMV156EM Microwave Oven
Have a GE microwave for three months bought it brand new and wife was making potatoes in it opened door to check on them and then closed door to continue cooking and it continues to count down but light...
The door switches are slightly out of alignment. If you run the microwave and shift the door up or down, the micro might begin working..
The control panel must be removed and the door switches adjusted. I would not suggest you doing this yourself, as it may affect the microwave leakage through the door gap.
Jan 02, 2011 | GE Microwave Ovens
My microwave is completely dead. I have checked the fuse in the plug and it is fine. Any suggestions?
What you are to do to solve the problem is to do a general troubleshooting on your oven below are instruction to follow.
The Microwave is a counter top model with a variety of preset cooking options, including timed cooking at a variety of power levels and sensor-cooking settings for popcorn, rice, beverages and single-serving reheating.
The sensor cooking and reheating features detect increasing humidity levels inside the microwave and automatically adjust cooking time for various types and amounts of food. This microwave also includes a turntable and an electronic control panel.
Instructions below are step by step solution for your oven
  1. Check to see if the microwave will start. If it will not start and the display panel is blank, you may have a power problem. Unplug the microwave and then plug it back in, making sure that all three prongs of the power cord are fully inserted into the wall outlet. If this doesn't work, check your home's fuse box. Reset the circuit breaker to restore if necessary.
  2. Ensure that the microwave door is fully closed. Press the Clear/Off button to cancel any previous cooking instructions. Re-enter your cooking program, including cooking time and food weight if necessary, and press Start.
  3. If "Err" appears on the microwave display, press the Clear/Off button and reenter your cooking program. The "Err" message will appear during the sensor-controlled programs (Popcorn, Rice, Beverage or Reheat) if the door is opened before steam is detected or if no steam was detected within the maximum amount of time allowed by the microwave. Be sure to leave the door closed during these programs, at least until time is shown counting down on the display panel.
  4. If your control panel will not work or if an "L" is displayed on the screen, press and hold the Clear/Off button for a full three seconds to unlock the control panel.
  5. If your sensor reheat program is resulting in under- or overcooked food, first try decreasing the amount of food in the microwave; the sensor programs are designed for single servings of food. The sensor reheat function works by measuring humidity inside the microwave--do not use a tightly-covered dish with this setting because no moisture will be able to escape and the food will overcook. Be sure that cooking containers are dry; moist containers will increase the humidity in the microwave and mislead the sensor, resulting in undercooked food.
  6. If your turntable is not rotating, first check to ensure that your food container is positioned so that it can freely rotate without hitting the microwave's interior walls; using a smaller food container can fix this problem. If the turntable still will not rotate, lift the turntable from its support and replace it carefully, ensuring that it rests evenly on its support.
Good luck.
Thank you and thanks for using fixya.
Nov 23, 2010 | Neff H5470N0GB Microwave Oven
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave turns on and counts down but won't heat up/cook
Ok just figured this out! It is a problem with the alignment on the lower door switch. I took the cabinet off and lifted up on the door switch slightly and voila! It works. You could probably fix this without taking it apart, just lift up on the door ever so slightly. I hope this works for you.
Jan 13, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Sharp R530EK
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
If you only need a switch, you can order a universal type here for $5 postpaid.
Otherwise, the best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Jan 02, 2009 | Dacor PCOR30 Convection/Microwave Oven
Frigidaire FMV156EM Microwave Oven Logo
599 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
