Question about Toastmaster 1183N Bread Maker
The kneading paddle won;
The paddle in the bucket freezes up, soon after it starts kneading, then it tries to go again but only in spurts with screeching. Now I heard a loud screeching and it had completely stalled and wouldn't turn at all.
The place the bucket fits into spins freely but it is not making contact with internal parts. There are bits of black rubber that have been 'chewed' loose from the bucket gear on the outside center shaft. Is this repairable? I love the bread baker and have not had problems until it started stalling It is a Corner Bakery model #1183 Serial # 709KB10428
Thanks, Dorothy
  • 5,603 Answers
I have found it necessary to periodically remove the shaft from the pans of breadmakers and clean off the carbon that is "coked" grease. I polish the shaft with crocus cloth and clean out the bearing. Often one has to remove a "C" clip to dis-assemble the shaft from the pan.
After cleaning I relube it with FOODSAFE grease before re-assembly.
Posted on Sep 11, 2009
I can't pause my breadmaker?
That little bit of time won't make any difference. Just remove your paddle and try to get the dough ball back in as soon as you can. Don't worry about 10 or 15 seconds.
Apr 01, 2013 | Cuisinart Automatic Bread Maker W/ Delay...
Paddle won't turn properly while kneeding
does the pan turn at all while kneading? Does in knead at all?
Feb 03, 2013 | Oster Model 5812 Bread Machine Loaf Pan...
Where can I buy a kneading blade for a Toastmaster bread machine, Model 1185?
The Breadman Model TR888 uses the very same kning blade paddle as your Toastmaster Model 1185.
Click here:
http://www.directpartsandproducts.com/tr888-kneading-paddle-p-8818.html
Hope this helps!
Jun 11, 2011 | Toastmaster Kitchen Appliances - Others
I put all ingredients in the machine and turn it on it shows 5.00 but nothing else it's not warming or kneading or anything. Please let me know what's the problem
push the "stop" button until it beeps..........then unplug your machine....then plug it back in...... and push the select button again and again until the program you want appears in the read out then push "start" your paddle should start kneading slowly unless you choose whole wheat, then it might take about 1/2 hour until it starts kneading.... If you choose program 1 or basic it should start kneading right away.... please let me know if this works....
Oct 25, 2010 | Panasonic SD-YD205 Bread Maker
NOT FREEZING PROPERLY
If your outer bucket is leaking down the liquid brine solution it won't freeze properly. The rival buckets are bad about leaking. You might try pre-conditioning the outer bucket before making your attempt at freezing. Just fill the bucket to the weep hole with water and let it sit for about half an hour, then pour out all but about 4 inches of it and start adding ice and salt.
Jul 04, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
Why did the kneading paddle on my 1148X bread machine quit working. This happened the third time it was used. It did the initial mixing and resting. When it started the kneading process again, the blade...
Hi, If this is the third time using it, it could be defective. Return it for service. If not under warranty, try a few things. 1) Make sure the pan is inserted in the machine correctly. 2) Make sure that the paddle is not sticking, or the sealed bearing on the bottom of the bread pan is not broken or frozen. (Take pan out and see if you can turn the paddle freely by hand). Or finally, the belt may be loose and slipping, especially when it takes more power to knead the dough the second time. Good luck...Hank
Jun 12, 2010 | Toastmaster 1148X FastBake Bread Maker
My chefmate breadmaker - The liquid and flour don't get mixed..
Even though you hear the paddle moving, the belt may be slipping so the paddle does not rotate at full force. Please check the tension of the belt. You can access the motor, belt, pulley assembly inside the base of the machine. Also, please check to make sure the kneading cycle is run fully. Check the manual to see length of cycle. Good Luck...Hank
Jan 22, 2010 | Chefmate TR 7000 Bread Maker
Panasonic SD-YD205 Bread Maker: Paddle gets stuck then continues.
Take the bread pan out of the machine and run a kneading cycle. If it is noisy with the pan out then you can take the belt off and try a kneading cycle again. If it's quiet, the yep it's the belt. If still noisy its a gear or the motor itself. If everything is quiet with the pan out then it's the pan itself. There is a sealed bearing in the pan that allows the paddle to spin. The seal on the bearing leaks oil and the bearing either freezes or does not let the paddle spin freely. There is no replacement for the sealed bearing ..and a new pan is needed. Good Luck Hank
Dec 10, 2009 | Panasonic SD-YD205 Bread Maker
The kneading paddle won't turn and something internally seems to
http://www.fixya.com/support/p101012-toastmaster_1183n_bread_maker
Sep 11, 2009 | Toastmaster 1183N Bread Maker
Kneading paddle having problem kneading
Sounds like you might need a new belt. If it works ok with nothing in it but wont when the dough is in there
Feb 13, 2009 | Breadman TR875 Bread Maker
Toastmaster 1183N Bread Maker Logo
310 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Mohamed Ismail
Mohamed Ismail
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
