Question about Refrigerators
ICEMAKER I HAVE A WHIRLPOOL REFRIGERATOR MODEL ED5NHA. THE ICEMAKER HAS STOPPED. THIS SOMETIMES HAPPENS IF THERE IS SOMETHING BLOCKING THE SENSOR AND AFTER I MOVE THINGS AROUND IT WILL USUALLY WORK AGAIN BUT IT WILL NOT WORK THIS TIME. ANY SUGGESTIONS. IS THERE SOME SORT OF RESET BUTTON?
  • Anonymous Dec 13, 2007
    Model GD5SHAXLT02,the icemaker stop three weeks ago and no mere ice.I did the check up on the sensor ON-OFF etc and nothing happends.
    Appreciate if you have a possible solution
95% of the time the problem is with the water valve on the back of the fridge that supplies water to the IM. I would verify first if this is your problem. It is a part that often fails and is quite common occurance.
Posted on Dec 10, 2007
Have a Hotpoint model HSM25GFRA SA Ice maker stopped did some checking ond found the water solinoid to ice maker was open and replaced it. But still no ice, have removed ice maker, cleaned and defrost
Check to see if there is ice blocking the tube to the icemaker. Sometimes when the valve is giong bad or the icemaker sits too long without making ice the tube will freeze and block up with ice.
Feb 14, 2014 | Hotpoint HSS25GFP Side by Side...
Good Afternoon: I have model # GD5RHA. My icemaker is not working. I have checked everything. Can you tell me where the icemaker wire shutoff arm is located please?
Looked up the model number and your IM does not appear to have an arm on it. Sometimes the optics get blocked by the ice bucket being out of place. Looked up your tech sheet and it turned out blank. Incomplete model number most likely. Gotta shoot from the hip. Just gonna toss a manual your way and hope for the best:
IN DOOR ICE SYSTEMS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 18, 2010 | Whirlpool Refrigerators
Model: ed5fhexnbo1 ....Noise comes from freezer side; sounds like the motor or fan is rubbing something. This occurs intermittently. Ken
You could have bad bearings in your evaporator fan motor. I would also check your fill tube for your icemaker and make sure that it has not frozen and popped out of place. Sometimes they will pop out of place and when the icemaker is filling it will drip some water down onto the evap fan blade causing it to rub on a block of ice. If theres not ice build-up then replace the evap fan motor it should take care of your problem. Part# 4389144
Hope this helps _MJ_
Feb 10, 2010 | Whirlpool Refrigerators
Refrigerator
it would have double solenoid where water enters fridge at the back. Possible screen is pluged inside the solenoid. Possible one solenoid is burned out. Sometimes the water entering to ice maker would freeze inside the tube and stop water from filling ice maker. Check those things for now. Another thing to ckeck to make sure nobody pulled the icemaker arm up to stop icemaker
Jan 08, 2010 | Whirlpool GS6NBEXR Side by Side...
Icemaker stopped working
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Model ET14NKXEW00 Top freezer 1996 model Whirlpool refrigerator
Water from the melted evaporator frost is normally drained down to a pan mounted on the compressor . The heat from the compressor is normally enough to vaporize this water. Sometimes the evaporation may be reduced due to- high humidity (in the kitchen). Try keeping the exhaust fan on for a while. Also check if the drain line is blocked or shifted out of the drain pan.
Oct 24, 2008 | Whirlpool ET0WSRXML Top Freezer...
Whirlpool ice maker water line frezees in the frezzer section.
  • usually when this happens the water valve is slowly leaking water. this small amount of water will freeze inside the fill tube for the icemaker; eventually blocking the water flow.
  • you might need to change your water valve going to your icemaker.
Jul 04, 2008 | Whirlpool Refrigerators
Whirlpool icemaker
I changed the filter and it stopped making ice. I finally discovered that the rubber fill spout had frozen somehow. I heated the tube with my wife's hair dryer and the top of the fridge just above the tube. A pencil sized chunk of ice fell out of the tube and it started making ice again.
Jan 16, 2007 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Refrigerators Logo
434 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
