Question about Microwave Ovens
Panasonic microwave model NN-2959: can't open door.
Microwave Model NN-2959 : can't open door. 14 years old, worth repairing or not?
  • Anonymous Mar 22, 2014
    open
Your DOOR LEVER probably is broken. To open the door remove the filter (2 screws at the top) then remore the control panel by removing the screw holding it in place UNPLUG THE MACHINE. then unlatch the door. BUT I am trying to find a door lever and find they are no longer availabel.
Posted on Dec 21, 2009
  • billchambers Dec 21, 2009
    part may be a door lever a82565130 from Panasonic found one at Angel Appliance 1-877-835-6030
    Sergeant:
  • 269 Answers
Hi! if the parts is to much expensive i think it is not worth it. considering the years it has serve you.
Posted on Sep 12, 2009
Testimonial: "I thank you for caring about my problem and taking the time to respond! You are right. 14 years is respectable and I could consider buying a new one."
If you have decided not to repair the unit, I would buy the door from you, I need one for my microwave that is otherwise working fine but the plastic doorframe is broken.
Posted on Jul 06, 2010
NN2909/NN-2959. My cooktop bulbs blue out together! Changing bulbs does not correct problem. Is there a fuse somewhere? Any way I can fix this problem?
microwave oven model number but of course their is a fuse in anything. follow power cord from wall into cooker and look for a fusible link is what I would do. Both cooktops out at once is an indication of no power.
Dec 29, 2016 | Microwave Ovens
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
This is actually a one-year-old Panasonic Inverter NN H965WFX 1250 watt microwave. The light inside flickers and staggers a bit, and the microwave does not heat or cook properly. The first time this...
Inside is a screen which sometimes arc. These are normally available from the dealers and is not very expensive. Microwaves are dangerous and repairs are better left to trained people.
Jan 03, 2018 | Panasonic NN-H965 Microwave Oven
My Panasonic NN-CS596S cuts out after nearly 40 secs on the microwave program, and then displays the H98 code. My contract with the Gas Board provides a call- out engineer, he has changed the Magnatron,...
It should be worth having it looked at. The magnetron is the most expensive part to replace, since it is new I would have it looked at it might just be a door or interlock switch(cheap fix). Here is a link for DIY's http://appliancehelponline.com/microwavetroublshootingvideo.html there are also videos on testing each component at http://appliancehelponline.com/microwave.html
Oct 07, 2010 | Microwave Ovens
Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Sep 11, 2009 | Microwave Ovens
Light, fan and timer work but microwave does not
Microwaves are pretty much a non repair item. It will cost you more to fix than it would to replace.
Aug 14, 2009 | GE Advantium 120 Convection/Microwave Oven
My microwave turns on when the door is openned.
UNPLUG AND DONT USE you have a bad or wet control board . if you gave cleaned the keypad in the last day or so , it might dry out in a few days ......if not it just went bad . most control boards are between 130.00 and 160.00 without looking up your oven ... so in most cases its not worth the repair
Jan 19, 2009 | Panasonic NN-S763BF Microwave Oven
Microwave Ovens Logo
327 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
