I have a ra5 102 201 dectron,the first stage keeps going off on low discharge fault by the way my name is Jody
  • Dennis Boxerman May 11, 2010
    Don't know your exact system, but a low discharge is usually due to low freon level or a low out door temperature. Both effect discharge pressure and temp.
What to do with carrier infinity ac fault code 81
"Low capacity thermal lockout"#81. What this tells me is your 1st stage cooling(low capacity) is locked out for 4 he's due to a dirty outdoor coil, weak outdoor fan motor run capacitor, slow outdoor fan motor, overcharged with freon, restricted or short cycling outdoor airflow(overheating), damaged discharge temp switch, faulty outdoor circuit board. That's all the scenarios I can think of for now. Hope this helps!
Aug 24, 2017 | Carrier Heating & Cooling
Tip
2 Stage Furnaces More Comfort and Save Money
Two stage hot air furnaces can save you money and make your high efficiency furnace even better. With your furnace running at low fire instead of cranking up to the highest heating output in mild weather you can be more comfortable while saving money.
Many people think that they are getting the best they can get by buying a high efficiency single stage furnace. What they often don’t realize is that they could do better yet and for a few dollars more have a high efficiency 2 stage furnace that could keep them much more comfortable.
There are 2 stage hot air furnaces that are now available that will only run at half fire if the full fire is not needed. With a two stage furnace in mild weather when only a little bit of heat is needed, the furnace will have longer run times on low fire. This will keep you room temperatures from getting too hot before the thermostat reacts and shuts the furnace off again. This will help to keep your temperatures from overshooting the set point and help to keep your home much more comfortable.
Many of these two stage furnaces also have variable speed blowers that run at a lower speed when heating on low fire. This will also help to save money on your electric bill, because these blowers use very little electric when running at these low speeds. Air noise from the blower running at a high speed is also reduced.
If you are thinking of replacing or installing a hot air furnace, make sure that you ask your contractor to give you a price on installing a two stage furnace. The price difference probably will not be much higher than a high efficiency single stage furnace. However the comfort of the two stage furnace coupled with the electric savings will make the extra money well worth it.
on Dec 14, 2009 | Heating & Cooling
I brought my irulu tablet yesterday downloaded some apps and it started to freeze when I switch it off and back on it takes long to load and also resets itself
I had similar problem with HP tablet which was not answered by them. Later I found it has got DEEP DISCHARGE problem.ie. it is allowing the battery to go to deepdischarge stage due to circuit problem. The circuit should make itself dead and prevent the battery to go to that level. Virtually the battery enters into COMA stage ! Keep it in switch off stage for 48 hours with charging on - so that the battery comes to life again and charges itself. Later my tablet is OK.
Jul 30, 2016 | Tablets & eReaders
The message am getting is battery charging fault. i managed to book the car in at one of the renault dealerships. Please advise if it is safe to drive the car as the car keeps beeping
If you have a battery charging fault, do not drive the car as it will cut out at a stage when the battery gets too low and leave you stranded. Wait dill the dealer can do the repair
Aug 17, 2015 | Renault Cars & Trucks
I have a nucool mini refrigerator 2.8 cu. ft. I changd modules and still runs hot .Thanks
Dear Friend!
Without knowing exact fault, replacing modules will not solve the problem. Check compressor is working, If so, keep your arm on condenser coil or discharge line. If you feel hot, it's working If not no gas. If working, you will get slight whistling sound on initial stage in freezer, as gas flows. If no soul\nd like this, gas chocked. You have replace filter drier and flush out system and recharge gas. My humble advise to call repairman to check completely. Thanks.
Feb 01, 2011 | Haier Heating & Cooling
My Garnet Pro 200 tube guitar amp has low volume
You must first isolate the stage that is causing your problem. Start at the master volume control by injecting a signal using a screwdriver. If you get a good level of hum from the speaker then output and phase splitter stages are ok. Work your way back to the front end by touching the screwdriver to inject hum into the input grid of each valve in turn to isolate weak stage. Check anode and cathode voltages on valve of suspect stage. Check cathode bypass capacitor and anode/grid coupling capacitor for open circuit. If fault in output stage check screen grid resistors for open circuit. WARNING high voltages exist in valve amps, keep one hand in your pocket and do not hold on to the chassis while testing.
Feb 21, 2010 | Audio Players & Recorders
Dc1804f charger
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Nov 06, 2009 | Makita 18V LXT Lithium - Ion Cordless...
My Grundfos JPS4 1 HP Pressure Booster Pump keeps coming on for a
SOUNDS LIKE YOU HAVE A LEAK DOWNSTREAM PROBABLY UNDERGROUND. THE PUMP HAS NO REASON TO COME ON EXCEPT TO BUILD THE PRESSURE BACK UP. HOPEFULLY YOU HAVE A GAUGE IN THE DISCHARGE LINE YOU CAN WATCH IT DROP AFTER THE SYSTEM SHUTS OFF. HOPE THIS HELPS, JODY
Apr 27, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
