Question about Cameras
Lens will not extend on startup of Pentax Optio M10 causing shut down after blurry display for about 1 second. I can hear that the lens is trying to extend and it clicks and jitters when pressed during start up. It is as if something has come undone mechanically internally.
    President:
  • 2,761 Answers
Two possibilities: one bad, one not so bad. If you've recently dropped the camera you've likely damaged the lens tube (housing), and the camera will require professional repair. Before you panic though, the problem that you described is frequently battery related. Make sure that your batteries are the correct type for the camera, and that they are fresh/fully charged. If the batteries are OK, the problem may be due to corrosion on the contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, wipe the ends of the batteries, and replace them in the camera. This cleaning process works about 90% of the time, and I hope that it cures your problem.
Posted on Sep 11, 2009
Lens
Sorry. It is broken. The lens was most likely jammed on start up when trying to open or close when shutting down. The really bad news is that the cost to repair it is close to the cost of a new camera. (I have had several like this, casio, sony canon, nikon and olympus.)
Jun 24, 2013 | Pentax Optio E10 Digital Camera
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
I am getting a Lens error on my Pentax Optio 60 Digital Camera. How do I fix it?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 19, 2011 | Pentax Optio 60 Digital Camera
Turns on for a few seconds, lens starts to extend, turns off.
Assuming that the battery is OK, the most likely cause for this behaviour is an out-of-kilter lens drive. If you are lucky it's just some dirt or grit jamming the lens. Try blowing some compressed air in the lens grooves, or place the camera with unextended lens down and gently tap it to dislodge any dust or sand. Repeat while lens is extending. If this fails, GENTLY try to help the lens extend. Do not force (you risk permanent damage to the lens, assuming there is no damage now). If the lens rotates while extending, still gently try to help it to rotate, twisting in the direction of rotation.
Unfortunately, it's possible that the lens drive is actually damaged and can't be realigned manually. In this case the camera will need to be repaired. Also, even if you succeed in refitting the lens - you'll hear a slight "click" and the lens will start working happily - you'll need to exercise extra care in case the drive is no longer up to spec.
Unfortunately, "extending lens" cameras are very sensitive to accidents such as turning on while something is blocking the lens from extending fully. In most cases there's an overload sensor which will retract the lens and power off the camera - but sometimes the overload will have damaged the internal drive train, which is often (not very cleverly, in my opinion) made of plastic instead of metal.
Apr 16, 2010 | Pentax Optio M50 Digital Camera
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
My Optio won't stay powered on.
Hi drdaved It seems to be a battery cotact problem. The battery contact pins might have some rust. Try to clean them with a rubber and alcohol (after the rubber)
Dec 03, 2007 | Cameras
Lens extends after power, then buzzes, then goes back in and shuts off. It was working not too long ago. And I haven't dropped it. But I just tried to use it and it doesn't want to work. The battery seems...
Go to this website: camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera
I couldn't fix my Pentax Optio S10, but this is the best web site I found to address the problem we both have with lens extending, buzzing, then shutting off. I took my camera apart, and found that my lens was cracked around the edges.
Nov 01, 2007 | Pentax Optio S7 Digital Camera
Pentax Optio 50 Digital Camera Lens Error
Not really, it sounds like the lens has been bumped while it was extended. Unfortunately, the "buzz" you hear is the gears stripping one another. The only fix is to have the lens assembly replaced, which usually costs upwards of $200. I see this problem at least 3 times a week in my shop.
Oct 27, 2007 | Pentax Optio S50 Digital Camera
Automatic retract of lens and camera shutdown after startup
A faulty switch it seems- Repair shop job unless you have some warranty left. Check Pentax technical help team
Jun 03, 2007 | Pentax Optio 330RS Digital Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
