Question about Panasonic PV-V4022 VHS VCR
I have a Panasonic VCR PV-V4202-A. I want to
I have a Panasonic VCR PV-V4202-A. I want to delay the starting of recording a TV show for several hours. How do I do that?
  • Panasonic Expert
  • 244 Answers
You need to go into the menu and look for timer recording,then set in the channel,dateand time the program starts,then press the timer button.It will not start recording until it gets to the time the program starts.
Posted on Sep 17, 2009
Testimonial: "Thanks for the feedback. I have not yet tried to impliment his suggestion, but, assuming it works, it will be very helpful. Thanks much. Joe"
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
How to record movies from the tv to my Panasonic PV V4521 vcr
If you need the user manual you should be able to get it free from the Panasonic website.
If not can you explain the problem more clearly, for instance are you trying to record digital channels and the vcr has not got a digital tunner etc?
Dec 27, 2009 | Panasonic PV-V4521 VHS VCR
VCR will not record (PV-V4624S)
SET YOUR TO RF LEVEL " LOW" OR YOUR CABLE CONNECTION IS WRONG CHECK IT.IF THE PROBLEM REMAINS, CHECK IT ON STANDARD DEFINITION TV FOR RECORDING.IF THE PROGRAM RECORDS OK THEN IT ID NOT COMPITIBLE FOR DIGITAL SIGNALS. BUT IF NO RECORDINGS PERFORM CHECK THE VIDEO HEAD CLOGGINGS OR MAY BE MAIN "IC" PROBLEM.
Feb 21, 2009 | Panasonic PV-V4624S VCR
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Panasonic PV-V4021 VCR.
An analog VCR can only be used the same way as an analog TV. You should be able to set the VCR to the converter boxes output channel ( 3 for example) and then set the VCR to record that channel at the correct times. Then just tune the converter box to the correct channel. Please note that if you try this while you are at home (recording one thing while watching another) you will wind up recording whatever is on the channel you change to.
Oct 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Recording on a Panasonic VCR
This problem is undoubtably dirty or worn video heads. Try using a good quality head cleaning tape. If this fails, re-post, and I will explain how to clean heads by hand.
Dave Duff
Mar 01, 2008 | Panasonic PV-V4022 VHS VCR
Recording VHS from TV/VCR combo onto DVD
This machine does not support DVD recording. Are you trying to make a tape from a DVD, by some chance?...accordianman
Jan 21, 2008 | Panasonic DMRES15 DVD Recorder
PANASONIC PV4022
One way is to manually select the missing channel with the numeric keypad, then push "add." There is also an auto program function puts the VCR into a search mode, adding all channels where a good signal is found. Early VCRs (like late '80s or so) did not have this auto mode, but many later ones did. Also, make sure your VCR is set to the "cable" or "CATV" mode not "off-air" Do you have the VCR manual? If not, recheck your model and see if Panasonic has it online at http://service.us.panasonic.com/OperMan/Default. aspx I looked at at a manual for a PV-4651, and it showed functions which sounded similiar to what you need. Check pg. 10-12
Aug 12, 2007 | Panasonic PV-V4022 VHS VCR
Vcr freeze frames tv programs when turned on
No nO NO the cable out from the cable box goes to the input of the VCR and the VCR output goes to the TV connection. Good Luck
Jun 05, 2007 | Panasonic PV-V4525 VHS VCR
Panasonic PV-V4022 VHS VCR Logo
165 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
