Question about Hitachi CP-X401 Projector
On one of our 3 hitachi projectors i am receiving a invalid scan frequency error, any ideas?
Hi my projector starts up for about a minute then turns off any ideas please ? many thanks
hi,
Here i have add a link to the manual for your projector. See page number 32and 33. It describe the lamp reset and filter reset. Try these first.
http://www.manualowl.com/m/Hitachi/PJ-TX100/Manual/72291?page=33
OK
Sep 21, 2011 | Hitachi PJTX100 Multimedia Projector
I am trying to figure out how to set the scanner frequencies
  1. Press hold then enter then enter the channel number where you want to store a frequency. Then press "FUNC" and "PGM" and the channel number will appear.
  2. Use the number keys to enter a frequency including the decimal point you want to store.
  3. Press "E" to store the frequency into the channel.
  4. Note - If you entered an invalid frequency in step two "ERROR" will appear and it will beep three times. Enter a valid frequency.
  5. The scanner automatically rounds the entered number to the nearest valid frequency. ie an entry of 155.174 will automatically be rounded to 155.175
  6. When you enter a frequency into a channel, the scanner automatically turns on the delay function and "DLY" appears. When delay is turned on the scanner automatically pauses scanning.
Mar 19, 2011 | Uniden BC72XLT Handheld Scanner
Cant get any frequencies to program
hi select a bank ,Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears. 2. Use the number keys and to enter the frequency (including the decimal point) you want to store. 3. Press E to store the frequency into the channel. Notes: • If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency. • The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475. • When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning
Mar 18, 2011 | Uniden BC72XLT Handheld Scanner
I cannot figure out how to program my scanner to the fire frequency.
To program any known frequency into your BC72XLT, power the scanner ON, and then:
1. Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears.
Notes:
• When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning 2 seconds after the end of a transmission before scanning proceeds to the next channel. To turn the function off or on, press Func + Dly.
• If you enter a frequency that has already been entered elsewhere, the scanner sounds an error tone and displays the channel that was duplicated. If you entered the frequency by mistake, press then enter the correct frequency. To enter the frequency anyway, press E to
accept.
4. To program the next channel in sequence, press E then repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 16, 2010 | Uniden BC72XLT Handheld Scanner
We are receive the problem of frequency out of range pls tell me how to solve it. thanks you
Try lowering the resolution on your computer then try again. Once the resolution is too high you will get this error message.
Dec 14, 2009 | Sony VPL-ES3 Multimedia Projector
BC72XLT
Here is the directions to store frequencies in your scanner:
Storing Known Frequencies
Into Channels
to store.
Notes:
Operation 2 seconds after the end of a transmission before
accept.
Dean
Rollin CBs
Feb 19, 2008 | Uniden BC72XLT Handheld Scanner
Infocus Litepro 540
Hi John
Hook up a PC and check if you get a image.
If you don't , then there is a Mainboard problem !
Nov 22, 2007 | Hitachi Performa CP-RS55 Multimedia...
Blue patch
you didn't state how many hours are on the unit, but I'm guessing close to 3,000 hours, that is when most brands have LCD panel failures, due to the heat over time the coating on the lcd panels burns off, the panels start to burn up, and it gets worse with time, and you notice it more when you put a fresh bright lamp in. if it is low hours then you could have a bad lamp, that casts a bad tint, but it sounds like fried LcD panels, a sure way to tell, is put up a white back-ground screen and see if you see discolored "BLOB" in the center of the screen.
keeping the filters clean, and the projector cool is the best way to prevent this.
Nov 09, 2007 | Hitachi PJTX100 Multimedia Projector
Hitachi CP-X401 Projector Logo
241 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
