After being unplugged and left in a cold car for 9 hours, won't turn on after then plugging into electricity. Has a new battery purchased 6 months ago. Electricity outlet working and checked connection of plug to be sure it's tight but no lights on the computer at all. It has been plugged in overnight but still no lights and won't turn on.Compaq
Comments:
Dec 10, 2007
- Thanks for both of the above suggestions. I did plug it in as soon as I brought it in the house. I'll try taking the battery out and just using the ac power. If that doesn't work I'll assume something shorted and I'll take it for repair. Thanks again.
-   I shut my acer travel mate 2310 off at night and when i went to turn it back on nothing happens the charging light is on and says fully charged but if i click on the power button nothing happens can anyone assist me on fixing this this has happend before and my aunts bf fixed it and didnt buy anything so i know theres a way please help if you can please email me at ducci25@hotmail.com and put subject acer labtop -   ducci25
Jan 16, 2009
-   my travelmate 4000 and it won't turn on. When i push the power button the light on the power button lights up, but then it shuts off. Please tell me how i can fix this.
-   laurelgreisc
Jun 19, 2008
-   Having a problem with my hp dv4000, it was working fine the night before. I came home the next day and the thing wont even turn on. When i hit the power button the liilte lightning bolt on the front of the computer lights up but that is all nothing else. Any suggestions?-   daveg40152
Feb 17, 2008
-   I left my laptop in my car for about 20 hours while the temps were quite cold. Since it was unplugged for so long I knew that the battery would have drained so when I brought it back in, I plugged it in right away and hit the power switch. I see no response from my laptop. I was wondering if there are any suggestions. I left it plugged in overnight to see if it would charge, no response. Now I left it outside it's bag, indoors though. Will it warm up and start functioning again or should I just give up on it? Is a repair possible for this case? Thanks-   maimoon
Feb 13, 2008
-   My acer aspire 3690 is just over a year old and was working fine whilst using it. However its started to slow down whilst i was on the internet and when i turned it off an hour or so later i wanted to go back on it but it would turn on, it was fully charged but when i tyurned turning it on, the acer screen comes up but then its says there a fault in the harddrive and wants to check it. I let it do it several time but it doesn't get any further and after a while the screen becomes lite up but black. Can anyone help ?-   Guest
Did you let the laptop warm up to room temperature for at least an hour before you connected it to the electricity supply?
Since its been in a cold car, condensation can build up inside the laptop which is why sometimes its best to leave it to warm up.
You may have some shorting on the motherboard if it was plugged into the supply as soon as you got it out of the car.
when i am working outside in the cold with my lap top it just stops working. part of my job requires me to out working with it when it's cold or wet. It is a panasonic notebook built for heavy use.
