Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
The beater does not work. the restart button is not burnt or the switch
  • 430 Answers
Remove the hose and reinstall using the alignment arrow at the top of the hose insert. Be sure the hose clicks securely and does not twist or rotate right or left.
Then remove the power head from the wand and eliminate the wand. Plug the head directly onto the hose and plug the cord into the wire socket under the hose.
Flip the switch on the head fully back and forth to see if the head will run without the wand. If it runs put the wand back in place and inspect electrical connections and plug terminals when reinstalling. Post back with what you see and results
Posted on Sep 11, 2009
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Kenmore intuition non-turning beater bars, beltless model
When you press the reset button does the vac motor start but the bars do not turn? If so the drive belt may be broken that drives the bars. If so you will have to replace the belt. If the motor does not start it is possible the belt could be jammed or the motor seized or burnt out. If it's not very old check to see if it's still under guarantee.
Dec 07, 2014 | Kenmore Vacuums
I have a Dyson Animal bagless vaccume and can not get the beater bar to work. I have cleaned it really good and seems that it doesn't switch from bare floor to carpet
Is this a new vacuum for you, or are you familiar with how it works? The beater bar button is on the front of the handle. It is a large half button with the picture of a beater bar on it. This button has to be pushed down for the bar to work.
If you already knew this and your vacuum is one you have had for awhile, it may have a worn or broken belt. The manual should tell you how to replace the belt, and you should be able to purchase one through the dyson website http://dyson.com under PARTS or at the store where you purchased the vacuum.
Please let me know if this works for you.
Jan 11, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson dc17 amimal's main turbine head is not working, is there a reset button or any other solution? I don't think it is the belt!
Right next to the power switch is a switch that will turn on/off the beater brush. Push firmly on this button and see if that turns it back on. It will turn itself off if it has too much resistance on it from getting tangled in something like a long carpet fiber that wraps itself around the beater brush. Check and make sure it's not bound up by something and then press the on/off button for the beater brush.
May 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Rug beater does not work, vacuum does I just was vacuuming the rug and it suddenly stopped, beater will not turn on.
The beater bar will turn itself off if something became lodged in the brushbar area - it turns itself off so that it doesn't cause any further damage. If this is the case, recline the machine, turn it on and press the gray button next to the red power button. This is the brushbar's ON/OFF switch. If that doesn't solve the problem, call the Dyson helpline for further assistance.
Jul 11, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
Apr 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater bar stopped working
hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Beater Bar/Brush Won't Turn
Sometimes dust,lint and thread can work its way into the bearings on both ends,take the beater bar out and see if you can turn it in your hand,if it doesn't inspect the ends and clean them.Use what ever you can find to pull out the threads.Or take it outside and hose it off.
Feb 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Dyson DC 17 Asthma allergy Vacuum
I had a similar issue. I called Dyson. Hey why not, the number is right on the from of the machine. SO IS the beater bar on/off button, right next to the big red on/off switch. It does have a safety off when something jams the bar from rotating so the motor doesn't burn out. I also removed my sock and on restarting the thing, the beater bar would motor was not turning on. I thought the reset would be inside but no, it is right outside in plain view, which I didn't see either. It is a grey button opposite the big red on/off switch. Boy did I feel dumb after that phone call!
Aug 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
69 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
