Question about Motorola Mobility RAZR V3
I WANT MY COMPUTER TO SOUND LIKE A KEYBOARD
I WANT MY COMPUTER TO SOUND LIKE A KEYPAD I CAN PLAY
THE KEYPAD ON THE COMPUTER AND USE THE KEYBOARD FOR A KEYPAD
My samsung n150 plus keyapd is not working properly
It sounds like a key gets stuck on your keyboard, which keeps sending signals to your computer; especially as it seems fine using an external keyboard. When the laptop is off, try typing on each key a number of times, especially the 'suspect' ones, m and 0 (?)
Have you spilt Coke or coffee on it at any time??
Feb 10, 2014 | Samsung Computers & Internet
Speaker problem
I don't know exactly what to say about this one, but if your speakers are acting like microphones, you might want to be sure you've got them plugged into the speaker jack, not the microphone jack.
Speakers technically CAN pick up sound vibrations, but generally they don't unless they are specifically set up that way by professionals. That's all I've got, sorry.
Nov 28, 2013 | Acer Aspire 4736Z 4736G 4738ZG 4733Z...
Keyboard repeats j without contact
You need to adjust your keypad inside.
Good Luck
Aug 21, 2012 | Compaq Presario CQ60-220US PC Laptop
My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
Click "Start." Click "Control Panel" in the right panel.
Click "Accessibility Options."
Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys."
Click "OK" to unlock the keyboard, including the keypad.
Unlock Touchpad
Click "Start," then "Control Panel."
Click "hardware and Sound," then "Mouse."
Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
hope this helps
Aug 17, 2012 | Synaptics PS/2 Port TouchPad
Keypad on right side doesn't work
Try pressing your numlock (top left of the keypad) and try the numbers again. Try your keyboard in another computer -- if they still dont work, you have a hardware failure ... time for another keyboard. If it works on another computer, then I would recommend right-clicking on "My Computer" and selecting "Manage". Go into the hardware manager, and delete your keyboard, and reboot. The Windows will find your keyboard and reinstall the drivers, hopefully resetting whatever configuration was previously blocking your keypad keys.
Apr 10, 2010 | Apple M9034LL/A Keyboard
I can't turn off the keypad tones on a LG Xenon phone
To turn off the beep on the keypad beep or voice on an LG Xenon, go to menu; settings; sound; volume. From there you can raise or lower the volume or mute the keypad and other sounds.
May 25, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Play casio keyboard through midi and acer laptop
Update your usb driver, make sure you have the latest miditzet driver, check your connections, and make sur sure you get all this for the operating system you are using. This should help.
Good Luck
Fehdi
Jul 09, 2008 | Computers & Internet
Compaq keyboard
Computer sound can be controlled by even mouse forget keyboard multimedia keys - play with control panel and sound - if are using servers its hard to enable sound all the time. Sound is banned issue...
Jul 03, 2008 | Compaq Computers & Internet
Motorola Mobility RAZR V3 Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
