GE DBXR463GB Gas Dryer
Problem for GE DBXR463GB Gas Dryer
How to get into dryer to convert to LP
By claudialuvsl on Sep 10, 2009
I just purchased a GE DBXR46366WW gas dryer and have ordered a conversion kit for LP (WE25X0217) but cannot figure how to get in to the orifice. There are 2 screws inside up above the dryer opening. But is also connected at the bottom in some fashion. How do I get into the dryer to swap parts? Any other tips on replacing these parts?
Best Solution
posted on Sep 11, 2009
Very Helpful)
Controlfrk
Rank: Guru  GE Washers & Dryers  Expert
Rating: 95%, 98 votes
Disconnect power. Turn off gas.
Open the door and look along the front upper edge of the door opening. In the top left and right rounded corner of the door opening you will see screws going upward into the top. Remove both screw and raise the top.
Look down inside the open top dryer from above on each left and right edge there will be a screw holding the front assembly to the case of the dryer. Remove 1 on each side.
The dryer front can now be pulled toward you about 3 inches at the top and then lifted off the bottom clips and swung away to the right from the case. Be careful not to strain any wires connected between the case and the front.
This will expose the underside of the dryer along with motor, Gas valve and venting for checking and vacuuming. Be careful of the ignitor. It is very brittle and can be easily broken
Gas service should should be done by professionals only as improper servicing can cause fires, explosion or death from asphyxiation. TEST for leaks after reassembling gas parts.
Perform thorough vacuuming and reverse the above process for reassembly. Good Luck
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you...looks like great instructions. I'll try it. " - claudialuvsl
Popular Solutions for GE DBXR463GB Gas Dryer
Questions and Unsolved Problems for GE DBXR463GB Gas Dryer
Do you recommend GE DBXR463GB Gas Dryer?
Answer
Answer
The dryer spins but does not heat up? Am I correct in assuming that it's the thermocouple or what... (More)
Answer
it gets hot but takes too long to dry clothes. Does it use double heating element? A handyman... (More)
Answer
my maytag atlantis wont get hot and makes a loud noise.
Answer
My dryer was running fine yesterday until suddenly I turned it on and it is making a very loud noise... (More)
Answer
Hello Sir, I have GE DVLR223GGOWW Gas Dryer. It trips after running few minutes. What is the... (More)
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , NY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
