Question about Amazon Computers & Internet
I have emg active pj bass pickups 2vol. controls and 2 tone controls. I would like them to work independently and blend together when they are both on. I don't think I can fit a switch in the control cavity so I would probably need a diagram without a switch, or if you have a way I can do it with the room I have please let me know. Phil
Thank you for your concern, but I took it to a guitar repairman,and the problem is solved. pmusso5
Posted on Sep 11, 2009
How do i wiring an active pickup and a passive pickup in same guitar
Not hard - just wire up one pickup and leave the other one alone. The active pickup will have wires that say "output + and - " - just use those to connect to the same place you would attach a passive pickup. Also, an active pickup will need space for a battery (9v). I weould consult EMG pickup installation for diagrams. You will also probably need to replace the guitar jack with a TRS, where the ring is a "killswitch" for the battery when the guitar is disconnected.
Try this diagram set: http://www.emgpickups.com/skin/frontend/emg-2013/default/pdfs/2-tw-2v-1t-only.pdf
Feb 14, 2015 | Music
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
Feb 07, 2013 | Schecter STARGAZER 5 Bass
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
I have install resently an emg spc pontentiometer in my guitar but i get a fanny noise in the middle position of the volume pot. i also use passive single coil pickups.do you have any idea why i have this...
EMG's use 5k pots if you bought the ones for the actives, unless your single coils are active you can't use it. 250k or 500k is standard.
Sep 12, 2017 | EMG Music
I NEED TO KNOW HOW TO USE THE FOUR CONTROLS AT THE BODY OF THE WASHBURN FORCE 4 ACTIVE BASS
two of the controls are volume, two are tone, (at least usually). the best way to use the controls is to try one at a time till you find the combination that pleases you most. I have been playing bass for 40 years and have 7 bass guitars, two with active pickups and two that acoustic electric
Mar 17, 2011 | Washburn Force 4 4-String Electric Bass...
HELLO!MY NAME IS KOSTYA SOME QUESTIONS ) BASS STU HAMM URGE 2 HAVE ONLY ACTIV?NOT ACTIV/PASIV? CAN I PLAY AS PASIV??IT S VERY IMPORTANT FOR ME!!))))
If your Bass has Active pickups then it will only work when there is a battery. It will not work without a battery. If you do not want the active pickups then you can have someone swap out your pickups for passive ones. In fact, you can probably get passive pickups for free in exchange for your fancy (expensive) active pickups. Good Luck
Dec 06, 2010 | Fender Artist Series Stu Hamm Urge II Bass...
Computers & Internet Logo
62 people viewed this question
Top Amazon Computers & Internet Experts
Craig Butler
Craig Butler
Raghavendra Nagaraj
Raghavendra Nagaraj
Tom Chichester
Are you an Amazon Computer and Internet Expert? Answer questions, earn points and help others
