Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a 42' walk behind craftsman. I am trying to replace the pull string but cant seem to wind it correctly to where it retains tension. any input?
  • 47 Answers
Is the spring broke if not wind the spoll up a couple of times then install handle
Posted on Sep 11, 2009
Mfirefighter173@aol.comhave a craftsman 17 hp lawn tractor and dont know were to put the spring that engages the mower blades, had to take apart to put in new mandril and cant seem to find were to put this...
There are four pulleys on the deck. Two for the blades, one idler, and one tensioning. The two smaller ones are the idler and tensioning. The tensioning is the one on the right. The post coming out the top of the pulley is where the spring goes, it slides over the top and a clip goes throught the hole at the top of it to retain the spring.
I hope this helps.
Aug 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do i replace pull string on craftsman 20/14 chainsaw
Remove the cover containing the cord rewind mechanism, untie the cord's knot in the center of the mechanism and remove the old cord by unwinding it from the pulley. Thread the new cord through the hole it goes through on the outside and wind the recoil mechanism so that it has sufficient spring tension to rewind the new cord. Use something appropriate to immobilize the pulley while you thread the cord through the center and tie the knot. Slowly allow the pulley to retract and wind the new cord onto it. Replace the cover. As an aside, sometimes when the cord breaks and the pulley snaps back quickly, the rewind spring can break.
Jun 24, 2011 | Garden
I pulled the starter rope out of the unit. How do I take the unit apart to re-wind the starter rope?
Take the cover off and look under it, you should see a plastic round disc that the rope winds on, You will need to locate the string and get it out of the cover where it passes through,once this is done, you will have to turn the disc the correct way to tighten spring ( you should be able to feel the pressure building as you turn, if not go other way, or the spring is broke, in wich case you need parts. If all is well, when you feel tension on it and have enough....not to much...just think about how much pull you had before it broke,because when the rope comes out it gets tighter towards full pull of rope, HOLD tension and put string through the hole on cover, once you have it through tie your handle back on, you should be able to release and jossle to get the rope back in the groove, Place on machine and see if you have enough tension that it will retract in cover when pulled and let go, if it does not you will have to repeat procedure, and tighten spring.....Do not get carried away with the loading of the spring......TIP you can shorten string if you just lack a little bit of it retracting in cover because it gets tighter when pulled out....Good Luck!
Nov 26, 2010 | Husqvarna Craftsman 200 Mph 430 Cfm Gas...
My pull string came off my lawn mor.i replaced but dont know how to rewined it back up help is there a trick to it.
You have to wind the spring and the housing that holds the spring. Then insert string in and tie the end in a knot. Probably like you have it now. But you have to wind the spring first.
Oct 02, 2010 | Craftsman Garden
Had to replace E string on Baby Z. Having difficulty getting the string on guitar to wind Any assistance would be great!
Normally you leave string slack enough at the start so you can get 3 or 4 winds before it is at tension.
While winding, pull string sideways to keep gentle tension on the string.
They have cranks to speed up the winding process you caanbuy that are inexpensive.
Here is an excellent video of how to:
http://www.ehow.com/video_4396928_replace-strings-acoustic-guitar.html
Dec 28, 2009 | Dean Guitars Dean Baby Z Electric Guitar...
Craftsman Walk behind lawnmower how to replace the starter pull string
Remove cowling to acces pull start assembly. Have new cord on hand. Remove old cord fragments. Wind rotor 4-5 revolutions to tension spring and hold while threading new cord into slot. Knot new cord and slowly let it wind back into assembly.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
I have a power master 420 which the pull cord broke on i have replaced it however it doe not seem to want to rewind and is a pig to start now any suggestions please
you must wind the spring up by hand first clamp the sping mecanism down with visegrips or clamp and then feed string trough and tie off. release clamp and string will feed back in
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Apr 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
49 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
