I have a new digital projector ,i want to connect old style suround sound type speakers to it (have to strip the wires back and put in clips) the problem is icant get any sound out of any of it i need help .
Be sure that the projector you have is in the correct mode(ie.av,scable,tv.etc...)then make sure its in the right mode for say if you want to use the avs instead of the cable(ie.m,d/k etc..)this should solve most problems especially if you bought yours in china like i did the instructions were verry,verry limited on information.
Posted on Sep 17, 2009
Mighty Bright clip-on Book Light. Broken switches - a plastic piece of the on-off switch fails and falls out.
Just buy a new one really if really need quick fix 1 dollar at store for 2 wire switch just tie wires one to first wire second to other wire to make bridge solder if u know how else just strip wires and twist together
May 02, 2016 | Home
I am changing out a Clarion ARX7570z to NZ500. Have most of the bugs worked out but I need a wiring diagram for the ARX to figure out the which wires are which. HELP!
the wiring diagram is out dated for the cassett player ....
here is what i know
red is ignition swichted
yellow is contstant power
black is ground
blue power antenna
blue with white strip amp turn on
gray + f right speaker
gray/black strip - f right speaker
white is + L front speaker
white with black strip is - L front speaker
green is + L rear speaker
green with black strip - L rear speaker
purple is + r rear speaker
purple with black strip - r rear speaker
your orange with white strip is illumanation not used
100% of all aftermarket radios are color code this way if you have install diagram for new radio it will be the same as old clarion radio ..
but make sure u have a digital volt meter to check power on red and yellow wire and comming from the factory harness be for you connect new radio just to make sure it does have powers and check other wire for power also just so you dont blow up new radio ... you can blow up a radio by connecting a wrong wire faster than you can blink your eyes ..... if you need a wire diagram for you modle car email me with it a http://www.tintingbyfredjohnson.com and go to contact and send email
Dec 28, 2010 | Clarion ARX7570z
How do I wire the system
You would require an amplifier wiring kit which will contain all the wires to get power and signal to your amplifier; six feet of 14-gauge speaker wire for the subwoofers. Your speakers should have come with their own speaker wires.
The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire.
The complete installation process is as follows
#1
Disconnect the ground (negative) cable from your battery first and foremost. NEVER work on the electrical system of your car with this connected.
#2
Install your new speakers. Start by removing the paneling of the speaker enclosure. Unscrew and disconnect the old speaker.
Ideally the speaker wire will be connected to the old speakers with a metal clip that can then slide right on to your new ones. If not, cut the wire off the old speakers, strip about half an inch of it, then cut the last 6 inches or so off the speaker wire that came with your speakers so you have the proper connectors with a little wire attached, strip a half inch of those wires and twist connect them to the existing speaker wire. Bend the twists so they are in-line with the wire and wrap each connection in electrical tape so no wire is showing to protect them.
Attach the connectors to your new speaker. Make sure to connect the negative wire (-/black) to the negative terminal on the speaker and the positive wire (+/red or white) to the positive one. Screw the speaker in place. If you have component speakers, and therefore a crossover, make sure the crossover is secured in the speaker compartment so that it does not bounce around while you drive.
Wait to put the speaker enclosures back together until you have installed the head unit.
#3
Follow the instructions you got for removing whatever part of the dash covers it and take out your existing head unit. Connect the car stereo wire harness to the connector that was attached to your old radio and attach the other end to your new one. Connect the antenna cable (the single wire with the big plug at the end) to your new head unit as well.
If the speaker wires are separate from the harness connect them using the method of stripping, twisting, and taping described above. Do this one at a time or use masking tape to label the wire to avoid confusion. If you are having trouble figuring out which wires go to which speaker or which is positive and negative read the tip at the bottom of this section.
Do not put your new head unit into the dash yet-you still need to connect the amplifier to it. Put the speaker enclosures back together now.
#4
Attach the thick positive (+/red) power cable for your amplifier to the connector on positive terminal of your battery. The kit you purchased should have come with an o-ring on one end of the wire (you may have to crimp it on yourself, if so do it on the end with the fuse), this ring can be sandwiched in the bolt on the connector that connects your car to the battery.
#5
Put the fuse in the fuse holder.
#6
Run the power cable through the firewall of your car (there is usually an opening on the drivers side) and along to the back of the car where your amp is. It is usually best to run this wire under the plastic molding that goes along the bottom edge of your car, you never want the power cable to come near any speaker wires. At the same time run the remote on wire (a really thin wire from the amplifier wiring kit), through the dash where the head unit will sit, along with the power cable to the amp.
#7
On the other side of the car run the RCA signal cable through the dash from the head unit to the amp (it's a pair of wires together with connectors on each end).
#8
In the back of the car pick exactly where your amp and subwoofers are going to go. Part of choosing this is that the thick black ground cable (negative) needs to have a place to connect to the metal frame of your car. This should be as short as possible, you never want the ground cable to be longer than 3 feet.
#9
Find a good screw or bolt, take if off and sandpaper the metal surface that the o-ring will make contact with, then screw it down tightly.
#10
Attach the RCA signal cable and the remote on cable to your head unit and attach the power, ground, RCA signal, and remote on wires to your amp.
#11
If you have not already done so, place your subwoofer box in the trunk and attach your amplifier to it if that is what you are doing. If you are not going to screw your amp to the subwoofer box then it must be secured to something else.
#12
Attach the 14-gauge speaker wires to the left and right channels of the amplifier and to the speaker connectors of the subwoofer box.
#13
Mount your head unit into the dash. Double check all of the connections on the back of it to make sure they are secure. Then slide your head unit into its slot in the dash and screw it securely in place. Before you re-attach the dash, reconnect the ground (negative) cable to your car battery and turn the stereo on and move around the car listening to each speaker to make sure everything is working properly. Then put the dash back on. You are all done!
Hope this helps
Thanks
Oct 08, 2010 | Jensen XA2250 Car Audio Amplifier
Can't get surround sound while playing the PS3. The surround works while watching cable
your suround sound system has been wired up so only cable plays throgh speakers
does your tv have a audio out RCA jack?
if so then connect the home theater to that
i cant help anymore because i dont know the suround sound model number ot what tv
Jan 11, 2010 | Audio Players & Recorders
6x9 hook up
yes conect the wire to the new speakers and it has to work
Feb 17, 2009 | Blaupunkt PCxt652 Coaxial Car Speaker
FINDING THE CORD TO THE SYSTEM FROM THE SPEAKER
From looking at the manual for your surround sound system
http://resources.jvc.com/Resources/00/00/93/GVT0150-001D.pdf
It looks like it just uses the regular spring-loaded clips to hold the speaker wire in place. All you need is regular copper braided speaker wire, nothing fancy. Then you strip about half an inch of insulation off the end of the wires, and pull back the spring loaded clip and put the wires in, then release the clip so it clamps down on the bare metal.
Speaker wire you can get from anywhere that sells the actual systems. I know places like Radio Shack (The Source by Circuit City) sells spools of it. Any other electronics store probably sells it too. It's common stuff.
Dec 13, 2008 | JVC TH-C6 System
Speakers work,dont work
try a light, clean coating of solder on the ends of the wire strands after you strip them to make the ends like a solid wire. this will give the wire jacks something to bite into.
without further info I would only guess that the tension is weak on the spring loaded buttons or speaker jacks
Dec 12, 2008 | Durabrand 5.1 Surround Sound Computer...
XBOX 360 Elite HDMI SOUND PROBLEM
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Nov 25, 2008 | Microsoft Xbox 360 Elite Console
External speaker hook-up
Ok, after A LOT of internet research I could not find any solution. So I decided to do a "chop suey" connection.
Went to Radio Shack and bought ...
Insulated Grip 2-1/4"Alligator Clips w/screw terminals 10 (five red & five black)
(A smaller alligator clip can be used if you have a soldering iron to connect the wires.)
30-Ft. 18-Gauge Clear 2-Conductor Speaker Wire
It cost about $15 for everything. Be sure to have electrical tape as well.
Stripped speaker wires to fit through each alligator clip and twisted it around the screw terminals of clip. Tapped screw terminal to cover wiring. Do this for 2 black and 2 red clips.
To install l laid the TV on its back and insterted each alligator clip to firmly fit on each terminal. Because the clips are large it will be a tight next to each other. Be sure to test one line and speaker first before completed the second line and speaker.
GOOD LUCK!
Nov 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Klipsh Promedia 2.1
I was face the same problem 2 year's ago.This problem occur when you move the speaker's here and there.at that time speaker's wire diconnected in inside...please check the whole wire by electricians for where exactly it is disconnected...
Sep 10, 2006 | HP ProMedia Computer Speakers
 Grubhead
Grubhead
