Question about ASUS DRW-1608P Dual Layer DVD±R/RW Retail Box Drive - 90-D40100-UAYZ 90D40100UAYZ (90D40100UAYZ) Burner
My CD will not open when I press (''open'')
My CD will not open when I press the ''open'' button. It is an ASUS drive DRW-1608P3S.
Gary
    President:
  • 3,278 Answers
Hi, Gary.
Give these a try:
In My Computer, right-click your CD's drive letter and select Eject.
Open a paper clip and insert in a tiny pinhole in the drive.
Hope one of these helps.
Posted on Sep 11, 2009
  • NinaE Sep 11, 2009
    If neither works, your drive needs to be replaced.
DRW-1608P 3S - doesn't show on 'my PC'. On 'device manager' there's the name but with an exclamation mark over a yellow circle. My daughter was deleting old programs before, to make room for photoshop....
you need the drivers for this hardware (DVD Drive) also sometimes a firmware update is necessary in order for it work properly
asus-drw-1608p3s-u-1-24-firmware-vt1486.html">http://www.inetbridge.net/forum/driver-asus-drw-1608p3s-u-1-24-firmware-vt1486.html
this is direct link http://www.inetbridge.net/forum/download/file.php?id=1622&sid=db1912e34e9b2e8bf95cd864a78f2d2b for the drivers / firmware download
download the file, extract the content and it will do the rest. make sure to have your dvd drive connected to your computer.
Mar 09, 2011 | ASUS (GENEIRC DRW-1608P BLACK)...
The drive is no more reading disks...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 10, 2010 | ASUS DRW-1608P3S DVD±RW Dual Layer Burner
Asus drw-16008p3s won't detect cd/dvd
If it is Not detecting try Cleaning the cd lens with lens Cleaner Cd, if still problem persist Visit Asus Service centre in Your Country
Jul 09, 2009 | ASUS (GENEIRC DRW-1608P BLACK)...
DVDs will not play on drive(DRW-1608P3S)
The reason for this issue is the lack of a codec software like Cyberlink PowerDVD or PowerCinema.These are paid versions.We could try installing a codec pack from Klite.Its free.The link is : http://www.free-codecs.com/download_soft.php?d=5075&s=775 Please let me know whether it fixed it
Mar 17, 2009 | ASUS (GENEIRC DRW-1608P BLACK)...
Does not read dvd
According to Asus there are many burned dvd formats that are not supported or simply do not work in this drive. Asus stated that most dvd-r should work but not all, and that is the only burned dvd media that works. You may want to look into buying a different drive.
Dec 17, 2008 | ASUS DRW-1608P3S DVD±RW Dual Layer Burner
Cannor Read DVDs
I have a similar issue to you, except that my dvd drive will only recognize a disc if I have booted up into windows with it in the tray...once in windows it will still think it has the first disc in no matter what disc i insert. If i boot up with no disc then it will never read it unless I follow the steps below.
A solution I found by pure frustration and trying all sorts of things is to eject the DVD tray and leave it opened, then right click on the dvd drive in 'my computer' and select the 'hardware' tab...then select the drive and click 'properties'.
A new window should open. Select 'volumes' and click 'populate'. Now close the window and insert the disc you wish to read, close the tray and repeat this process. Windows should now recognize the disc you inserted
Alot of trouble I know, but it works for me. Hope this helps.
Oct 22, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
Wont work
Sounds like there may be an issue with the drive itself. I would return it or replace it. As for windows...If this problem persists after a replacement, i would re install windows.
Dec 27, 2006 | ASUS DVD_BURN |DRW-1608P3S BK W/SW R...
Computers & Internet Logo
235 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
