Dell Inspiron 531s Desktop Computer   Logo
Posted on Sep 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cut and paste from internet explorer, freezes word
I have intermittant problems where the cut and paste function, copying written print or graphic photos from various Internet Explorer websites, freezes Word. There is no error message, but the hourglass remains on the page that freezes. Other open programs will eventually freeze as well if you enter them after the freeze. The only way I know how to unfreeze it is to press con + alt + del, which generates a help screen that allows you to shut down a system that is not responding. This allows all other programs to resume functioning normally. Sometimes the cut and paste function works perfectly from a particular website page, but then mysteriously, after several successful pastes, it will freeze, even if I'm copying from the same paragraph of material. Note: Because this has happened so often, I have noticed that if I cut and paste it into an empty e-mail document from Outlook Express, and then cut and paste from there back to Word, that this usually works - - also if I use the Notepad function. However, these extra steps take much longer. On rare occasions, the cut and paste function will not work at all in Word (it freezes), an e-mail document (which remains blank, though the mouse has been affected, but nothing can be seen), or Notepad (which may only copy part of the document and mysteriously be unable to copy a large majority of what's needed, even on repeated attempts) In addition, recently there is a noticeable start up problem in Internet Explorer, where it may take 30 - 45 seconds to open, or it may freeze, in which case I may need to close it and re-open it again. Sometimes it takes 3 or 4 attempt to finally open. All updates are current, we have run spyware programs, full system scans, a defrag, all with no noticeable change in the problems. Any suggestions?
  • gteenviro Oct 20, 2009
    how do Icut and paste my resume from my documents to a companies site ?
  • Anonymous Feb 02, 2010
    I have same problem - paste into WordPad is fine, but into Word or Outlook freezes those applications
Anonymous
Level 2:
  • Expert 106 Answers
  • Posted on Sep 11, 2009
Anonymous
Expert
Level 2:
Answers
106
Questions
Helped
69089
Points
303
Try to reformat your pc then,.,,
How do I cut an image from the internet?
There are several ways to capture images from the internet.
In your browser, right click on an image and select Save Image As...
or Copy Image and then paste into your graphics application.
Some web pages use programming to prevent copying images and the right click and copy/save won't work easily. There are ways around it, but you have to start hacking the copy protection code.
Do a screen or window capture:
On a Windows PC, look for a Print Scr (Print Screen) key on your keyboard.
Press that key and the whole screen will copied to the "clipboard" and can be pasted into another application. You may need to use another key in combination with Print Scr. I have to press the Fn key + Print Scr on my keyboard. Don't actually type the "+".
Also, the Alt key + Print Scr will capture only the current window, not the whole screen.
There are many screen capture programs out there as well. IrFanView is an excellent free graphics tool with a screen capture feature.
How to cut copy and paste in windows vista
Cut, copy, & paste in Vista work the same as in every other version of Windows.
Cut or Copy:
  • First, select the content you want to cut or copy. It can be text, graphics, or even files.
  • Next, select Cut (or copy) from the Edit menu. If you prefer using the keyboard, then use Control-X to cut, or Control-C to copy.
Paste:
  • Click where you want to put the content you just cut/copied
  • Select Paste from the Edit menu, or press Control-V.
Internet explorer task bar missing
Try pressing the left Alt key alone. Does the menu bar appear?
Try right-clicking the area where the menu bar is supposed to be. Try different spots around the upper part of the window, eventually you should see in the context menu an option to turn on the menu bar.
2helpful
When i copy something and try to paste it to email it to someone on :hotmail.com ..it doesnt paste. n the inernet stops working
your pc have an virus..... plz install antivirus software norton internet security is the best antivirus software
Copy paste
1. Type http://djlizard.net/software/Dial-a-fix-v0.60.0.24.zip in internet explorer address bar and hit enter and save the file on your desktop. after that try to open it and run dial-a-fix select all option then close it and restart the computer.
2. Try this:-- Internet Explorer, Tools, Options, Security tab, "Custom Level" button, Misc: "allow cut and paste for files", dot the "allow"
3. Try to run sfc /scannow and restart the computer ( Click on Start> Run> Type sfc /scannow )
remember inbetween the scanning you need to insert the windows XP sp2 Disk.
HP Photosmart D7460 Error Message
Remove the HP Smartweb printing software.
1. In the Start menu select All Programs > HP Smart Web Printing > Uninstall HP Smart Web Printing.
2. Follow the onscreen prompts.
You can also open the 'Control Panel' from the 'Start menu' and open 'Add or Remove' Programs. Select 'HP Smart Web Printing' in the 'Add or Remove' Programs window, and then click 'Remove'.
If the changes you make in the Page Setup dialog of Internet Explorer are not reflected in the Page Setup dialog of the Print Clips window and vice versa ?
This is a known problem, and not unique to HP Smart Web Printing. When printing from the Internet Explorer File menu, select File > Page Setup and make your settings there. When printing from the Print Clips window, click the Page Setup button and make your settings there.
Now install the smart web printing software from the weblink provided below:
After removing the smart web printing software, please visit the weblink and download the HP Smart Web Printing 4.05 software from the webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?softwareitem=dj-56929-5&cc=us&lc=en&dlc=en
Just copy and paste the entire link(without spaces) in the web browser and press enter.
For more information on how to install the software visit the below weblink which leads to a webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c00793678
After performing the steps mentioned above, check the functionality.
My written text
open a Internet Explorer browser
Click Tools, Internet Options, Fonts Button
Make sure Latin is selected as language Script
Webpage Font is Times New Roman
Plain text is Courier New
3helpful
2answers
Pasteing and how it works
If you mean pasting in relation to cut / copy & pasting
How it works
When you cut or copy something, for example text, it is saved into the clipboard. Then when you paste, the text that is in the clipboard gets pasted. You can paste that same text more than once, it stays in the clipboard until it is over written (by cutting ot copying something else) or you restart your PC.
How to use it
There is a couple of ways to cut / copy & paste
1. Use right clicking menu
you can select something, some text for example, then right click on it with your mouse and select Cut or Copy. To paste right click where you want the text to be pasted and select Paste
2. Use application's Edit drop down menu
you can select something, some text for example, then select the application's Edit drop down menu and select Cut or Copy. To paste click where you want the text to be pasted select the application's Edit drop down menu and select Paste
3. Use keyboard shortcuts
you can select something, some text for example, then press Ctrl + X to Cut or Ctrl + C to Copy. To paste click where you want the text to be pasted then press Ctrl + V to Paste
Hope this helps
-Magnon
10helpful
4answers
Outlook Printing Problems
open ie, change margins in file/page setup and try it again
3answers
Disable F3 function key from intenet explorer Use it from Flash
<html>
<script>
document.onkeydown = function(){
if(window.event && window.event.keyCode == 114)
{ // Capture and remap F5
window.event.keyCode = 505;
if(window.event && window.event.keyCode == 505)
{ // New action for F5
//alert('F3 key was pressed');
return false;
// Must return false or the browser will refresh anyway
</script>
<body>
</body>
</html>
NOTE:-PASTE ABOVE CODE TO YOUR HTML PAGE IT WILL DISABEL F3 BUTTON RESPONSE OF INTERNET EXPLORER THEN YOU CAN USE F3 BUTTON TO YOUR FLASH APPLECATION.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
