Question about Sony KDL-32S3000 32 in. LCD Television
Sony KDL-32S3000 HDMI ports have stopped working!
I own a Sony KDL-32S3000 LCD and I usually have it connected to my PC via a HDMI capture card as I regularly record video game trailers/walkthrough videos.
I recently moved house and so, had to disconnect everything. However, upon reconnecting everything and trying to get audio and video running from my x-box 360 to my pc and then to my tv via HDMI, I lost all signal.
I played around thinking I may have put the video input/output the wrong way round and eventually gave up to try another day. As a last resort, I couldn't understand why I wasn't getting video on my PC monitor through the software I always use so, decided to connect my x-box 360 directly to my tv only to find that no matter what HDMI port I connected it to, there was no signal!
I've got 5 different wires and all of them give me the same result. However, if I connect my x-box 360 to another TV via HDMI, all the cables send a signal that is picked up by the tv and display both video and audio so, I know it's not a problem with the console or the wires.
As a precaution, I also tried the composite and HD cables that came with the x-box 360 to see if I could get and image with sound directly to the tv and everything worked fine.
This leads me to believe it's a problem with the tv's HDMI ports but, I'm also wondering if my PC was able to somehow cause any damage to both the tv itself?
If it's any help, I'm using an Intensity Pro capture card for the video recording and until tonight, never had a problem with it!
Any help would be appreciated as this is driving me mad!
Thank you!
-B
pazman
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
  • 178 Answers
SOURCE: My satellite HD DVR output is connected to the
No, that will not damage the input. But if you are using component input and the green wire is off or not connected correctly it will prevent a picture from coming on. The green is the luminance and carries the main picture signal.
Posted on Sep 01, 2009
Testimonial: "Kudos to the experts. Thanks for the info. More power!"
SOURCE: hdmi port stopped working on sony bravia
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Posted on Mar 21, 2010
  • 60 Answers
SOURCE: How easy is it to repair a POWER FAILURE TO SONY
Usually it takes a little knowledge of basic electronics and some soldering skills. If you have these, then it never hurts to try to fix it yourself. Its already not working. Just make sure to work safe, unplug before working on it and close up before turning on. If you think its a power supply you might be able to see some blown capacitors, or you might get lucky and find a blown fuse inside.
Hope this helps
Posted on Jan 08, 2011
Testimonial: "Elrapido considering tome of day but as he said a little knowledge is a dangerous thing! - Guess I'll be off to Maplin to get a soldering iron"
joeguest2
  • 2080 Answers
SOURCE: I need to replace my
The instructions are in your USER MANUAL found at the following link:
http://www.docs.sony.com/release/KDL32SL130.pdf
In general though you should lay the tv screen side down on something VERY soft and flat like a bed so that the screen doesn't get scratched at all.
Then find the 3 philips head screws that hold the base to the tv. They should have replaced into the proper holes in the back of the tv when the base was removed initially. Unscrew and remove them and then place the base into position on the tv.
Once the base is fitted into position, insert and tighten the 3 screws again. The tv can now be lifted vertical again and placed where desired. Be sure not to press too hard on the actual LCD screen part when handling.
Good luck and post back how you make out.
Posted on Jan 23, 2011
KDL-50W656A. Where is T-con board located?
Typically it is the top most card usually placed aligned to the Top Edge of the LCD frame.
It will not have any ports (HDMI or VGA or RS232C or RCA)
It will also not have direct power connections.
Mar 22, 2016 | Sony KDL-50W656A 50" LED TV 1920x1080, 200...
Sony Bravia KDL-55BX520 HDMI ports won't work but the A/Vports t
Either the HDM firmware or the circuit board will be faulty. Connect it with an other known good HDMI cable, and make sure that the fault is not with the connecting cable.
Jul 22, 2015 | Sony BRAVIA KDL-55BX520 55" Class 1080p...
Sony tv faults
actually tv is not full hd & not sported play station signals through HDMI
Jul 19, 2014 | Sony KDL-32S3000 32 in. LCD Television
Sony KDL-32S3000 BLINKS 5 TIMES STUCK STANDBY MODE
Remove all speaker wires and try again. If it unlocks one or more speakers are bad. If not service required for amp. Good luck.
Apr 16, 2014 | Sony Bravia S-series Kdl-32s3000 32-inch...
Bravia service menu
make a new HDMI errors which is in main board .
Aug 27, 2013 | Sony KDL-32S3000 32 in. LCD Television
My notebook does not have HDMI but does have RGB (VGA?). How do I connect audio input from notebook to TV.
You can use a 3.5mm headphone jack to RCA cable, found here.
Thanks, and have a great day!
If my solution helped you, please don't forget to leave positive feedback!
Oct 08, 2011 | Sony KDL-32S3000 32 in. LCD Television
Sony kdl-32s3000 tv standby mode with 8 blinks-whats the problem???
Replace the main board (BU1 Board).
This is a problem in the audio circuit.
The part # is A-1257-244-A.
Feb 07, 2011 | Sony KDL-32S3000 32 in. LCD Television
Sony KDL-32S3000 32 in. LCD Television Logo
237 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
