Question about Kenmore Refrigerators
Kenmore model 596.72253201. Bottom freezer works, fridge does not
Kenmore model 596.72253201. Bottom freezer works fine, but upper fridge not cold. only holding at 72 degrees. Why?
  • Kenmore Master
  • 4,655 Answers
The most likely reason is part number 12566102 Adaptive Defrost control board. The next likely are the defrost heater and the defrost thermostat,Sea Breeze I will send you photos. below
Posted on Sep 11, 2009
  • 1 more comment
  • John Tripp
    John Tripp Sep 11, 2009
    12566102 Adaptive Defrost control board Photo And a photo of its location inside the control panel inside the fresh food compartment.
    ADC is number 13 top left of this small photo. You also will need to manually defrost the freezer by unplugging and removing the rear panel of the freezer to expose the evaporator coil. Defrost with a hair dryer and have a look at the defrost heater and defrost thermostat to make sure they are not the problem. I will send photos of the defrost heater and defrost thermostat soon but like I said the ADC is the most likely problem, Thanks Sea Breeze
    If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
    appliancepartsse@yahoo.com
    http://servicepartstec.blogspot.com/
    http://appliancepartsse.blogspot.com
    SEA BREEZE TIP's
  • John Tripp
    67001794 Defrost Heater
    12001937 Defrost Thermostat
    On either site listed above you can find the parts. Both are less than Kenmore. I do want you to test the defrost heater with an OHM meter to insure that it's not burned out. If you need to change the heater I recommend you also replace the defrost thermostat. You can enter the part number at each site the first and Rpair Clinic just click on the photo and enter the part number into his search feature. Repair Clinic will call that a different part number bu it is the same number for your model. Thanks for having your model number 95 percent of people leave that out. I will be here or at he email if you need more answers or assistance Thanks Again, Sea Breeze
  • John Tripp
Bottom of fridge not cold
After adjusting the settings switch or dial (usually inside fridge) you wait a couple of hours then see if bottom is colder. Most fridges (older models anyway) have an adjustment procedure. This worked for our Magic Chef purchased about 1994
Mar 03, 2013 | Kenmore Refrigerators
Freezer is working fine but the upper area refrigerator is not cooling properly. Temperature is barly cool but not cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer works, upper section not cooling on Kenmore bottom freezer.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 06, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge & Freezer won't get cold, but air is blowing
Is the compressor in the lower back working. You may short of gas . have it regassed
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not staying cold, periodically
CHECK FAN OPERATION   MOST OF THE TIME IT IS THE THERMOSTAT
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
317 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
