We bought a Cuisinart coffee pot DCC-1150. When the cycle ends, the unit beeps 5 times. This is very annoying and we plan to return the coffee pot to the store unless you can tell me how to turn the beeps off.
Sincerely,
Susan
when you thread the machine make sure to use every thread guide check to see if the bobbin is in correctly try changing the needle--normally flat side goes to the back the needle that your sewing with is it the right one for the thread & fabric clean under the needle plate & bobbin area for lint or loose threads
This definitely is a programming error on the machine. The problem is from the machines computer processor. The unit suffers repeated cycles. As regards the cost to get it fixed i cant give specifics because depending on the level of damage to the processor it might need replacement or just a little cleaning. But generally the fixing should not cost above $50 -$75 and this compared to the cost of replacing means it should be worth it. Although if you dont give it to a qualified personnel they might end up spoiling the unit more so i advice you look for a good expert and get them to fix it for you. The local dealership would be a good place to get a referral for an expert. Hope this support has been helpful? Thank you for visiting FixYa.
Feel the base where the pot sits if it is not Very Hot to the touch the heating element is bad, be careful not to burn your hand, the base heater on the machine performs a dual function it keeps the coffee hot and also boils and pumps the water through the machine, if it is hot the element is ok proceed to run a 50 % water 50% vinegar mitxure through 3 times to flush out sediment, make sure you run straight water through the unit afterwards three times to clear out any residual vinegar left in the machine
I had the same problem, go head with machine off and embroidery unit off also turn wheel toward you. If it still won't go try winding a bobbin that is what happened with mine it seemed to undo the stiffness. You can also take the cap off the wheel and make sure there is no thread wound around it.
Good luck if this does not work there are other tips but it would take all night to email all the steps. [email protected]
Make sure that the red disk (smaller than a floppy) on the underside of your embroidery unit has been removed. Remove and discard the red disk. It is used for shipping purposes only. Joyce
You can't. Believe it or not, it is supposed to be helpful! I know it is annoying though. I have owned my Husky for 10 years and it isn't something you can get rid of.
