Question about Acer Aspire 5672WLMi Notebook
Acer Aspire 5672 WLmi: Near - Black Screen
The screen is near black (a faint image can be seen if the screen tilted at an angle). Everything else is working fine....I'm not a pro in Laptop repair but want to try troublbleshooting options myself.
  • emailgmohan Sep 13, 2009
    Thank you...can you pleasetellmeif I can get an inverter (of this model) in Tokyo,Japan? If yes, any links to spare parts suppliers in Japan?
  • 674 Answers
Check your inverter try to use to other inverter...
Posted on Sep 10, 2009
Can the lamp be replaced for a Polaroid TLX03210B
You likely have a LCD set there which may likely use a back light inside to light the image, get the room as dark as you can and with a flashlight illuminate the screen from a angle, with set on if you can see the faint image on the screen of the program you have a Backlight issue'
1. Voltage not there or not being switched on for backlight.
2. Actual back light bad.
If the image can be seen with a flashlight one of the above is the issue and your "picture will appear very faintly" also suggests this.
Dec 18, 2012 | Polaroid Televison & Video
Black screen
If its LCD get the room very very dark and turn on--with a flashlight near the screen look closely at the screen to see if you see a very faint image of the picture or not---Most LCD flatscreen's (not Plasma) use what is called a back light to light the screen--light source.
If a faint picture can be seen that way the light is not on.
Dec 17, 2012 | Sceptre Televison & Video
ACer Screen is pitch black, but system runs normally
Check if this will work on an external monitor, if it will, you can point the finger at the following:
  • Inverter failed: If you cannot see any image on the screen even a faint one, replace the inverter
  • Backlight gone: if you see a faint image on the screen, the screen needs replacing
  • Possible failure (unlikely) of the vga cable
If it will NOT work on an external monitor, the graphics chip on the motherboard has failed.
Jul 20, 2011 | Acer Aspire 55345410 Notebook
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
I had some water on my screen and the screen is
dear sir my acer desktop pc sound not working sound properties open full option hide
rajan dubai
Mar 20, 2010 | Acer Aspire 5050-5410 Notebook
Power comes on but the screen stay`s black dose it have a screen lock or stand by
Black screens can be caused by many things the first bit of video runs through the ram, so try changing the ram or swaping it. the next thing that causes a black screen is the LCD Inverter or the back light bulb to test this is take a flash light and shine it on the screen at an angle and see of you can make any faint images out. Next dis-assemble the laptop and see if the processor is heating up or staying cool.
Hope this helps!
May 02, 2009 | Acer Aspire 1640Z Notebook
My acer 9300 when switched on shows a blank screen (black with some faint white back ground) but the process of starting windows goes normally coz i can view this when connected to a monitor whats a miss ?...
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 25, 2009 | Acer Aspire 9300 Notebook
ACER SCREEN IS BLACK BUT CAN FAINTLY SEE LOG IN BOX
Sounds like the backlight for the LCD is dead, either the light itself or the power inverter. If you're not a tech, you should take it in for repair. If you are a tech, you can usually find replacement lamps and inverters on EBay. Hope this helps.
-kinerf
Dec 09, 2007 | Computers & Internet
Acer Aspire 5672WLMi Notebook Logo
261 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
