FixYa.com
Tags:
Panasonic SA-XR55 7.1 Channels Receiver
Amplifier displays "Speakers are overloaded" and...
posted by dssm on Dec 10, 2007
Whenever my amplifier is switched on it displays "Speakers are overloaded" and switches off immediately. Any help?? Thanks.
Comment by dssm, posted on Dec 11, 2007
Hi Thanks for your suggestion. I have tried amp with speaker leads disconnected, but the same problem continues.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 10, 2007
Not Rated (0)
atariman
Rating: 70%, 1 votes
Either the amplifier protection circuit is kicking in due to a fault, or your speaker wires are shorting. Could also be a fault in a speaker - shorted turns due to overdriving. Check amp with speaker leads disconnected, and if OK, see above.
Can you Help with these Receivers problems?
Receivers
why do i get...
why do i get... Answer This...
Receivers
Need new door for Kenwood
Need new door for Kenwood 200... Answer This...
how to change radio station...
Hi I would like to know if it... Answer This...
subwoofer doesn't work
hooked up the panasonic with... Answer This...
SA-XR55 Input Selector broken
The Input Selector on my... Answer This...
Repair Service
Find Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
