Question about Microwave Ovens
I WAS UNDER THE ASSUMPTION THE GLASS TURNTABLE WAS TEMPERED GLASS, 2 MINS IN A COOKING PROCESS IT SHATTERED. THE MODLE IS MW8115SS
  • 5,911 Answers
Even tempered glass can shatter. It could have been a factory defect, or a small crack that had gone unnoticed until now. The glass is supposed to be durable, but it does happen from time to time. I found a replacement tray at repairclinic.com for $42. You can search by your model number or use item number 1174113. This was the only site that I could fins that carried the part for your oven. I hope this is helpful to you.
Posted on Sep 11, 2009
Microwave just stopped turning, everything else works
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Jan 05, 2012 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Turntable works intermittently
Good luck.
Nov 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not rotate on r24stm model
Good luck.
Walesarumi
Sep 29, 2011 | Microwave Ovens
Turn table turns some of the time
Good luck.
Walesarumi
Sep 26, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
I have a built in convection/microwave oven model AWM540IX, the turntable is not turning, is there anything I can do or will I need to get professional assistance?
Good luck....
Mar 21, 2011 | Whirlpool Microwave Ovens
The turntable is not working but I have power
Good luck.....
Mar 19, 2011 | Bosch HMT9656GB Microwave Oven
The turn table doesnt work
Good luck.
Mar 12, 2011 | Daewoo KOC-925T Microwave Oven
Turntable does not turn
Good luck.
Jan 13, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
Glass turntable in tricity tmc209 says "microwave only" What do I use for convection or combi cooking? Does turntable still need to rotate for convection cooking?
definately dont use the standard glass plate for convectional 'oven' cooking, as it will shatter. i have had TWO plates shatter so far before realising they should only be used for microwave cooking.
Aug 15, 2010 | Microwave Ovens
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
94 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
