Question about Westinghouse LTV-30W2 Television
My tv screen went black but still has sound - Westinghouse LTV-30W2 Television
Well ' that just Happened to mine right there and I ' turned the switch off at the side . and it still would not so what I did was there was a button on my remote saying'TV INSERT click it and then click! show screen (: Hope this Help's. its annoying when it happens:D
Posted on Oct 02, 2009
5 Suggested Answers
  • 8457 Answers
SOURCE: Black screen, only sound on my Plasma TV
Ur backlight video board is dead.U need a new board.
Posted on Sep 22, 2009
Testimonial: "Thanks for the help, I will now call Samsung as it's still under warranty."
budmrtn
  • 11361 Answers
SOURCE: tv screen went black and no sound
Look at the power supply first; look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. It sounds like at least you do have the 5V standby power supply working but the main supply is not getting the 'ON' command from the main board, or the power supply is gettin ght e 'ON' signal but failed to turn on.
Posted on Dec 02, 2009
  • 43 Answers
SOURCE: 47" plasma 1080p ... screen went black , sound
Plasma TV's have a shelf life. By that I mean the screen is only good for so many hours depending on the model. Most likely, you have burnt out the screen and the set will need to be replaced. The good news is, plasma TV's used to be better than LCD but that is no longer the case. You can get a very high quality LCD TV for a very low price now. Also they use a fraction of the power and don't generate all of the heat of a plasma.I'm sure this is not what you wanted to hear but the reality is that ALL plasma TV's do this eventually, and it is something that most salesmen back in the day didn't bother to tell customers. If you have an extended warranty, you may be able to get it replaced.
Posted on May 05, 2011
Testimonial: "Thank you for your honesty... it wasn't what I was hoping for , but it was something I needed to hear... Thanks again !"
caroldon
  • 17130 Answers
SOURCE: Plasma tv has sound but
This is a common fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Posted on Aug 17, 2011
Tv screen went black and will not come back up.
It sounds that the main board to this TV is damaged. Contact any service technician. If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Coby TFTV3225 32 in. LCD TV
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
I have a 52lb5d lcd tv and i have a black screen i plug my lap top in it then it went blank but i still have sound
I have the same TV and this morning went to turn it on. I have crystal clear sound but a black screen.
Feb 02, 2011 | LG 52LB5D LCD TV
Black screen on tv but still have sound!
i used to work on the warantee's for relysis from memory that was a deffo dead un we used to swap out on that fault im pretty certain its a dead processing board . . . sadly relysis uk went bust . . . .
Jan 17, 2009 | RCA F32450 32" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Televison & Video Logo
416 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
